Main :: Lowdown
lowdown hd400 head + peavey 4x10 cab
by Masterfett on 2012-10-24 08:00:51
Hi i was wondering if you could help me! i own a HD400 head and have been offered a peavey 4x10 cab cheap! however im pretty useless at the ohm stuff!
Spec can be found here:
http://www.peavey.com/assets/literature/manuals/pro410.pdf
willthis work with my head? ..
if so will it work well haha..
thanks in advance
Re: lowdown hd400 head + peavey 4x10 cab
by kweatherhead on 2012-10-24 08:18:17
Yes this cabinet will work perfectly with your HD400 head.  Since it is 8 ohms you will get a little over 50% of the total power your amp is capable of delivering.  I believe something in the ~275w range.  You could use two (2) 8 ohm cabinets (or one (1) 4 ohm cabinet) to achieve the total output capability of the HD400 amp head... 400w !!
The only caveat is... you WILL need a Speakon to 1/4" plug cable to connect your head to this cabinet as this cabinet only shows it has 1/4" connectors... any good guitar store will have them or you can order one off of EBay.
Best of Luck & Enjoy !!
Keith
