Main :: POD 2.0, PODxt Family, Pocket POD, FloorPODs
pod xt flash memory malfunction
by vvking on 2012-10-26 11:26:10.0780
monkey ,the newest version, do not recognize the flash memorys, in the panel appear as a question mark (?),  so i can not updated and also cant reset to factory preset, the thing i wish, and does not work with the footswitch FB4, for youre help and time thanks.
Re: pod xt flash memory malfunction
by toneman2121 on 2012-10-31 11:11:44.5020
what version firmware are you runnig? does it say pedal or fbv?
by Keebo on 2012-11-12 09:51:19.0130
vvking,
Have you had any success with re-flashing your XT?
I have had my POD XT for nearly a decade and has worked flawless until now.  When powered up, it now shows a dimly lit blank display.  I updated Line 6 Monkey and drivers with the intent to re-flash the unit but the flash memory is not recognized in Monkey.  It shows a question mark.
Does anyone know if the unit is officially dead or is there a way to get fired up again?
Thanks.
by toneman2121 on 2012-11-12 12:17:50.7870
if you check the serial number on the xt and it reads all zeros, it's probably gone. you can try reflash in safe mode
by Keebo on 2012-11-12 12:47:13.0660
The LCD is blank so no chance on checking the numbers.  The unit doesn't start up in safe mode so it may be time for retirement after many years of great service.
Thanks for your reply.
