Main :: POD HD
Midi ability confirmation
by ankrumc on 2012-10-30 13:53:24
I am able to control preset switches and setlist switches via midi (through logic) but I am unable to control footswitches, correct?
So I can
1.  Change all the setlists
2.  Change all the presets in that setlist (1A-16-D)
3.  But within the preset, I'm locked in unless I want to use my feet, cause they don't receive cc messages?
Thanks
Re: Midi ability confirmation
by silverhead on 2012-10-30 14:08:04
Yes, you can configure the HD500 footswitches to send midi messages. Check the MIDI ASSIGN page in the HD500. You can also use HD500 Edit to do this.
See manual Appendix B:
http://line6.com/data/6/0a06434dc1a55085c5d6532bf/application/pdf/POD%20HD500%20Advanced%20Guide%20v2.10%20-%20English%20%28%20Rev%20A%20%29.pdf
">http://line6.com/data/6/0a06434dc1a55085c5d6532bf/application/pdf/POD%20HD500%20Advanced%20Guide%20v2.10%20-%20English%20%28%20Rev%20A%20%29.pdf">http://line6.com/data/6/0a06434dc1a55085c5d6532bf/application/pdf/POD%20HD500%20Advanced%20Guide%20v2.10%20-%20English%20%28%20Rev%20A%20%29.pdf
by phil_m on 2012-10-30 14:17:52
The HD500 does respond to CC messages, and you can actually control the footswitches within a preset via MIDI. Check out page B.2 of the Advanced Guide.
by jimsreynolds on 2012-10-30 17:35:22
The trick is to think of it as a two part thing
1)   Assign a controller (footswitch or expression pedal) to toggle an effect or (for expression pedals) to change a parameter.
2)   Use a Midi CC to control the controller.
As the gents above have said, full details in the Appendix to the Advanced guide.  Make sure that your firmware is 2.0 or greater.
