Main :: James Tyler Variax Guitars
Support community for JTV.
Bug on HD 500 edit sfw and JTV
by fenders74 on 2012-11-06 06:32:03.0990
Hi guys, I've found a bug using the edit sw....if You use the tuner on the pedalboard when you came back to preset for editing all Variax setting are 'gray' and not choosable....you have force to close and reopen the edit sw....I've tried a lot of time and everytime same problem.....
I've one JTV 59 with 1.71 fw version, last sw edit version and last HD 500 fw version...
Thanx for reply
Re: Bug on HD 500 edit sfw and JTV
by Line6Hugo on 2012-11-08 11:46:00.8940
Hello,
This should not happen if you are using the necessary JTV 1.90 fw version, latest edit version and the latest POD HD500 fw version.  They are required in order for all of the software versions to be compatible with each other.
Regards,
Line6Hugo
