Main :: DT50/DT25
One dt25 head, two cabs...set up stereo effects??
by jeremyburkett on 2012-11-07 11:50:49
I know that just getting two cabs running from one dt25 head will NOT let me set up a dual-amp situation (super clean out one cab with super lead out of the other), I would need two heads for that.  However, I am wondering if it is possible to set up the one-head-with-two-cab scenario to allow me to use stereo-friendly EFFECTS (delays, etc.) with disctinct sounds being sent by the one head to each cab, discriminately.  I have an HD500 running the entire amp-2-cab rig so I'm curious if I can edit the HD500 settings to acheive a stereo effect described above.  Any insights would be greatly appreciated!!
Re: One dt25 head, two cabs...set up stereo effects??
by TheRealZap on 2012-11-07 14:20:04
Not possible, the DT amps are mono, and will always play only a single channel of audio.
by geppert on 2012-11-07 18:14:38
Jeremy .... time to buy another DT25 head ... then, with one cab connected to each, you will get stereo through Line 6 Link ..... but as T.R.Z explains, not possible with one DT25 head.
Chck out the the Line 6 Link Connectivity Guide pages 2-2, 2-3
by jeremyburkett on 2012-11-07 18:34:10
Thanks guys!!!  I guess I'll start saving those pennies again......
