Main :: FBV MkI / MkII Controllers
Is FBV ShortBoard MK2 compatible with LD400PRO
by attilaracz on 2012-11-11 13:21:23
Well, Everything is in the title !   Also, what is the difference between mk1 and mk2 ?
Euhhh, just another quick one : is there somewhere a list (or better mp3 demos) of the extra sounds/presets you have in the LD400PRO when you connect an FBV Shortboard ?
Many thanks, Attila
Re: Is FBV ShortBoard MK2 compatible with LD400PRO
by TheRealZap on 2012-11-11 13:32:45
the mkii works fine... the difference is the usb port, and a couple of extra buttons...
neither of which will be much use with the ld400... i'd go for the mkii anyway unless you get a great deal on an mk1
the pedal is useful for alot of different line6 gear and can be used as a midi controller on your pc with the usb.
no demos of the sounds that i know of... some are good, and some are just showing off.. meaning not really useful.
i tend to use the express with mine rather than the shortboard, because i can get by fine with less than 4 tones for the bass.
by attilaracz on 2012-11-21 23:09:29
Thanks for the answer !  Attila
