Main :: StageScape M20d Mixer Community Support
Stage set up for larger clubs
by KyJamMan on 2012-11-20 05:45:05.0810
My question is. I want to run 4 tops 6 bottoms for the mains. then 4 monitors with a set of 2 tops and 2 subs for side fills. With all the different exports out of the M20d can that happen?
Re: Stage set up for larger clubs
by silverhead on 2012-11-20 05:55:31.2510
Assuming you are using Line 6 L3s/t/m speakers I think your setup is not too different from the large PA (2nd example) here:
http://line6.com/support/docs/DOC-2750">http://line6.com/support/docs/DOC-2750">http://line6.com/support/docs/DOC-2750
by dboomer on 2012-11-20 07:10:00.7920
The "limit" for using L6 link is 9 tops and 9 subs. You certainly can add additional speakers using analog connections and parallel them off digitally connected systems in any way you want.
