Main :: DT50/DT25
Stop boxes in front of DT 50 1x12 combo
by michaelmortimer on 2012-11-24 08:37:50.3610
I am a DT 50 and HD 500 owner. With the new firmware update for the amp I am thinking about running my set up a bit differently. I am messing with the HD unit as a midi controler as well as effects no pre-amps or amp models. I am wondering how the DT responds to overdrive units ie: tube driver, tube screamer in front of the amp. Has any one done this at all?
Re: Stop boxes in front of DT 50 1x12 combo
by DarthHollis on 2012-11-24 09:11:30.9850
The DTs work like any other amp with stomp boxes in front of it.  I have a POD HD 500 and I am using a separate Tube Screamer and a 535Q Wah in front of one or both.  Since I always put those in every patch, I have them available all the time and free up the DSP in the POD for more delays and pitch shifting.
Here's my problem.....  the POD works as a midi controler but only for individual foot switches.  I have not been able to make the POD change amps on the DT when you change a preset on the POD.  So for example:  you would store a whole combiniation of fx and maybe use the POD HD in 4 cable mode with no amp selected so you want each preset on the POD to change the amp setting on the DT.  It doesn't work, however.  Or at least, I could not get it to work.  The L6 link makes midi changes on the DT but I can only assign individual switches on the POD to send midi messages or even multiple messages.
Anyone have a solution for this?
by michaelmortimer on 2012-11-24 09:32:15.1890
http://youtu.be/T4oPvB7XCm4">http://youtu.be/T4oPvB7XCm4">http://youtu.be/T4oPvB7XCm4
Sean Halley uses a HD 500 simularly on his rig using a 4 cable method and a Bogner Duende. As i watched the video it seemed he was able to change the amp configuration with the midi control within the HD 500
by michaelmortimer on 2012-11-24 09:35:56.8390
I was wondering if the amp liked pedals. Some amps don't I dont have any drive pedals at this time so I guess I'll borrow a few and play around with it.
by DarthHollis on 2012-11-24 10:19:53.5650
I guess I should say that the DT amps are actually 30 amps.  Some of them may "like" drive pedals and some may not.  It's an amp like any other amp.  I guess I just don't understand why people think it's some kind of annomoly that reacts differently.
