Main :: POD HD
Tap Tempo not sending from HD500 Editor to POD
by Joel_in_Syracuse on 2012-12-01 20:10:27
If I set the Tap Tempo on the Editor, then send the preset,  the editor flashes at the new speed but the HD500 does not accept the new value.   I can toggle any other button via the editor, but the tap tempo will not send.  If I receive the existing preset from the HD500, the old tempo is still in place.   If I dial the tempo in via the HD500 directly, it'll change on the Editor.  Is this a bug?  Or am I doing something wrong?
Using an HD500 / HD500 Edit / Variax 300 rig, HD500 firmware updated to latest (v2.10).
Re: Tap Tempo not sending from HD500 Editor to POD
by mazuwa on 2012-12-01 23:33:54
I 've checked what you say.
If I dial in the tap tempo via my HD500 fw2.10 directly, it'll change the value on the editor immediately.
But if I use the editor for dialing in the tap tempo, no matter if I do it by entering the number or by tapping with the mouse, it mostly doesn't send the value.
Sometimes after I've changed the tap tempo on the editor, then swaped to another patch on my HD500 and returned to the old patch, it would work, but only sometimes.
This seems like a bug to me.
by preciousgeorge on 2012-12-09 20:23:12
In Setup, page 6, Tempo options, TEMPO sync Global or preset may come into play.  I get a bit confused on this too.  Hopefully someone can assist.
by ringuz on 2012-12-11 15:39:11
99% it's a bug....An annoying one!!
by mazuwa on 2012-12-11 16:25:49
No very preciousgeorge, I have already checked this. It works neither with global, nor with preset. It's a bug.
