Can PodFarm 2.5 - Stand along version work with Toneport UX-1
by coughdog on 2012-12-05 07:51:27
Had Toneport UX-1 as my primary audio device for years and was running Gear Box and PodFarm with no problem.   When I upgraded my computer (Dell Laptop, 6 gig ram, Win7) I started getting a lot of pops so I bought the M-Audio FastTrack Pro and updated to the PodFarm 2.5  Stand alone version.   This worked out fine but I was never able to run PodFarm2.5  as a separate program for direct monitoring but instead had to use it as a VST in Reaper which caused too much latency. Apparently, I can not share the ASIO driver simultaneously.    So, I decided to go back to my UX-1 to see if it can be done and I'm finding that my stand alone verstion PF 2.5 will not run with TonePort UX-1.  I though this would also count as an audio interface.
In summary, I have no problem running GearBox with Toneport UX-1 separately from my DAW.  I can no longer run PF verstion 1 at all; and I can not run PF 2.5 with my UX-1 nor can I run it with my M-Audio device simultaneously with my DAW.
Questions:  1.   Should I be able to run my stand along verstion of OF 2.5 with Toneport-Ux-1?
                  2.   Is there a way to simultaneously run PF2.5 with Reaper using the shared ASIO driver from M-Audio?
                  3.   Do I need to remove/reinstall PF1.0 to get that to work separate from PF2.5?
Thanks for you comments!
Re: Can PodFarm 2.5 - Stand along version work with Toneport UX-1
by TheRealZap on 2012-12-05 07:55:52
if by "standalone" you mean an ilok version you might have issues...
if you just have a computer version... use the license manager, and authorize your ux1 (needs to be plugged in)
and then it should work.
by coughdog on 2012-12-05 08:29:19
Thanks.  I will try this tonight.
by coughdog on 2012-12-06 06:11:44
All set TRZ.  Removed PF.1, ran monkey software, upgraded latest version of drivers, PF2.5 and ran the license mgr. Works better than before and its seems that I few more amp models were added (it also updated my classic amp collection).   Thanks for your help!
