New UX2/Pod farm user, sound quality problem
by duncankeith on 2012-12-10 14:29:39.9170
Just got it today and plugged it in/installed all the software, everything seems to be working as expected with the exception of an interference approx every 4 seconds.  An extremely nasty crackle is how I would descride it.
The setup is as follows:-
Guitar plugged into the 'normal' port, usb into the PC and Analog out (1/L) into my amp/speaker (through the direct port on it to miss out any effects on the amp).
The computer runs vista and is:-
AMD FX(tm)-6100 Six-Core Processor 3.30GHz, 4GB ram and 32-bit operating system.  I've read breifly about a problem with some AMD laptops, same thing here?
Thanks,
Dunc.
Re: New UX2/Pod farm user, sound quality problem
by Triryche on 2012-12-10 17:32:31.0990
If you run newest Monkey, do you have green ticks for drivers and flash?
http://line6.com/software/">http://line6.com/software/">http://line6.com/software/
by duncankeith on 2012-12-11 12:19:36.5360
Thanks for the response, this OK?:-
(On monkey v1.62)
by Triryche on 2012-12-11 12:25:23.2330
Sounds like a USB issue. Sometime it can be as simple as increasing our buffer size or changing the power scheme.
Check out this USB Troubleshooting doc.
http://line6.com/support/docs/DOC-4282">http://line6.com/support/docs/DOC-4282">http://line6.com/support/docs/DOC-4282
