Main :: POD 2.0, PODxt Family, Pocket POD, FloorPODs
POD xt freezes after turning on
by smelly666 on 2012-12-12 14:50:54.5470
Hi guys,
I've got a problem with my POD xt.
When I turn it on, then nothing happens, the display shines in that yellowish color
and the MOD button is on too, but except from that nothing else workes.
So I started the Line 6 Monkey to find out what the problem is and maybe do a flash memory reset.
The line 6 monkey tells me, that my device is connected, but it doesn't detect my flash memory.
Any help for that? Is my POD broken or is it something else?
Posted two pictures to clarify, what I mean.
Thank you very much for your help.
greetings
Re: POD xt freezes after turning on
by Triryche on 2012-12-13 08:29:15.2990
I see the problem. You are trying to install the flash mem while the POD is upside down!!
Just kidding.
Just to eliminate something simple, are you using the original power supply?
Have you tried flashing it in safe mode?
http://line6.com/support/docs/DOC-3827">http://line6.com/support/docs/DOC-3827">http://line6.com/support/docs/DOC-3827
by smelly666 on 2012-12-18 12:33:31.8180
Sorry for the delayed answer, but my POD worked again for one day, but now the same problem occured.
Regarding your questions:
Yes I'm still using the original power supply by line 6.
Tried to start it in safe mode, but nothing changed.
Wonder what kind of failure it is, cause it worked the other day and now it came back. So I
doubt, that it's a loose contact or something like that.
Thanks again.
by smelly666 on 2013-01-04 11:46:35.9940
still seems to be working from time to time, but on other days it won't work. Has anyone any idea, what I could do?
