Main :: James Tyler Variax Guitars
Support community for JTV.
Can I switch pickup configuration in modelling mode?
by irchamandy on 2012-12-19 14:47:08
I am new to JTV.  When I am in modelling mode in Lester setting (for instance, but my question is relevant for any modelling setting), I switch between types of Les Pauls using the pickup toggle switch.  Does this mean I can't control the pickup configuration when I am in modelling mode?
Re: Can I switch pickup configuration in modelling mode?
by silverhead on 2012-12-19 15:36:29
The pickup configuration is part of the selected JTV model. Most modeled guitars have several JTV model variants, each of which uses a different pickup configuration. For instance, in the Lester (Les Paul) model bank the same model of Les Paul guitar is modeled in three different pickup configurations, corresponding to pickup selector switch positions 1, 3, and 5. Position 1 models the Les Paul with the bridge pickup alone; position 3 models the bridge+neck pickups, and position 5 models the neck pickup alone (or vice-versa; I get the position numbers mixed up sometimes). Pickup selector positions 2 and 4 in the Lester bank provide different Les Paul model/pickup configurations.
See the JTV manual for details of which guitars and their pickup configurations are modeled in each model bank/selector switch setting.
You can use Workbench (the Variax editor program) to change the models and load your custom models into your JTV.
by irchamandy on 2012-12-19 18:58:36
Thank you for this clear answer.  In your example above, if I understand you correctly:
  • The 2 and 4 positions give me two different Les Pauls, each with a single, preset pickup configuration
  • The 1, 3 and 5 positions give me same Les Paul but with three different pickup configs
  • So under Lester (without any Workbench customization), I have three different Les Pauls: one with three pickup variations (positions 1, 3, 5) and two with one pickup variation each (positions 2, 4)
Am I understanding you correctly?  If I am, I will better understand how to read the manual.
Thank you,
Ian
by TheRealZap on 2012-12-19 19:41:45
if you have the 69 or 89, this chart makes it real easy to see whats going on:
http://www.vettaville.net/Variax%20Reference%20sheet%200606.pdf
the">http://www.vettaville.net/Variax%20Reference%20sheet%200606.pdf">http://www.vettaville.net/Variax%20Reference%20sheet%200606.pdf
theswitch on the 59 makes it a little different... although all the same models/pickup configurations are still there.
by irchamandy on 2012-12-19 19:47:11
Pardon my French but that is a fucking cool poster!  It is a great way to really understand all of my guitars.  Thank you!
by silverhead on 2012-12-19 20:11:16
Yep - you understand correctly. And the poster is a great visual reference.
The pickup selector switch mimics the modeled guitar's actual selector switch. A real Les Paul, with only two pickups, has a 3-position switch: Treble (bridge pickup), Mid (both pickups) and Low (neck pickup). The JTV models a Les Paul by using these 3 selector positions. But with 2 more available positions, it also models two other Les Paul guitars in one pickup configuration each.
The mimicry is more clear with the Spank (Stratocaster) bank. The same Strat guitar is modeled in all 5 pickup positions in the JTV, so it plays just like the real guitar.
by irchamandy on 2012-12-19 20:15:53
Thank you!
by TheRealZap on 2012-12-20 12:57:10
agree... always loved this poster... I need to print it HUGE and frame it for my music room
by faccurso on 2012-12-24 18:16:40
This poster is IT!
Thanks much.
