Main :: DT50/DT25
DT25 and midi
by pauliusmm on 2012-12-28 16:14:51.9420
If i understand correctly i can have lots of presets with different sounds if using DT25 with midi controller.
I would setup a switch on my midi controller to send multiple midi cc messages that would change the preamp type, topology, reverb etc... Then setup another switch with different preamp, reverb etc..
Am i on the right track?
But what happens when i dont use a midi controller after i messed with these internal hidden settings?
Are these changes saved? For example if i was using long ambient reverb and then i disconnect midi footswith and want to have a normal reverb - how to i do that? How do i go back to 'manual' mode- should i reset to factory defaults?
Re: DT25 and midi
by TheRealZap on 2012-12-28 18:30:02.6560
the settings are sticky... whatever topology you have selected will store the last used settings....
it's not really supposed to be used like you're suggesting... but probably could be...
be easier just to store 8 select settings... one in each topo for a channel and the same for the b channel...
then you have 8 settings that you could recall, just by sending the topology change midi info...
Re: DT25 and midi
by pauliusmm on 2012-12-29 10:27:48.8790
Thanks, so basically i can have a completely different sound just by flicking topology switch? Does it store reverb settings as well?
Re: DT25 and midi
by TheRealZap on 2012-12-29 11:27:36.9870
yes, and channel A and channel B can also have completely different setups (including reverb) on each of the 4 topology settings for a total of 8 different setups.
Re: DT25 and midi
by pauliusmm on 2012-12-29 14:46:36.1260
Thanks TheRealZap,
I can change the preamp type via midi , but what are the initial preamp/cab types stored when i take a new out of the box DT25?
Re: DT25 and midi
by pauliusmm on 2012-12-29 14:52:17.3210
Also what is the best and easiest way to edit these internal settings via PC?
Re: DT25 and midi
by TheRealZap on 2012-12-30 06:07:18.4700
the easiest way is this third party app: http://code.google.com/p/dtedit/">http://code.google.com/p/dtedit/">http://code.google.com/p/dtedit/
Re: DT25 and midi
by velosouk on 2013-01-24 07:28:07.9310
I am having difficult to store the presets I edit using "DT Edit". When I came back to the previous one everything is mixed. Is there any instructions of use ? Any tips ? One thing I notice is that we should not use the buttons, just the software, and not using then again when playing, otherwise it became a mess.
Any help ?
Re: DT25 and midi
by TheRealZap on 2013-01-24 07:43:00.2680
Your expectations may be the issue...
it won't save any knob positions...
Re: DT25 and midi
by animastereo on 2013-01-25 02:32:37.4190
I find it interesting that so many people (including myself) are so interested in enquiring about using the amp with midi.
Maybe I'm not the only one to hear that the pods cause digital or sterile issues.
My (and maybe others) 2c.  And maybe Line 6 should be listening.   This marketing (wether good or bad) is GOLD.
Re: DT25 and midi
by TheRealZap on 2013-01-25 04:25:00.7970
the exact same pre-amps are modeled in the amp as in the pod...
either way you are feeding the analog power amp a digital pre-amp.
you're supersonic hearing or projected desire to hear a difference can be from many things....
but technically there is no difference if setup the same....
same output mode, same cab, same etc etc...
maybe your hearing is so fine tuned that the length of the cable is bothering you...
if you can't get a usable tone with pod+dt... return them get your money back...
no sense in harming your mental stability any further.
THE PREAMPS ARE THE SAME 100% the SAME, whether feed from amp or from pod.
Re: DT25 and midi
by evilmikehoo on 2013-01-25 04:48:02.4030
The DTEdit polls your amp and tells you what the factory settings are. I created a wordpad document listing what the default settings are for each topo. I then created another document that I keep on desktop for quick reference as to what settings I've changed, so I don't hafta keep hooking up the midi cable. Just a quick click and I know what I've set up on, say, channel B - topo III. Gettin' older and the memory is goin' quick!! lol!!
Re: DT25 and midi
by animastereo on 2013-01-25 05:02:44.9640
Mate.  And I mean this sincerely because my amp ain't arrived yet.
(If the POD and amp do the mother humpa of a job that they are meant to I'll be the first to scream hallelujah and praise you as The Lord).
But I just find it interesting that others are finding issues enough to jump on line and request midi options.
I appreciate your help - I'm not being a smart arse.  And I'll even by the mutha humpa AES/EBU cable and Mesa Boogie tubes to give the set up the best shot.  But I know what I heard when testing it in the shop.
But I also know I only had 15 minutes with an amp at low volume with staff that didn't know thre shee-ite so am open to giving the time and effort that you say it needs to get right.
It arrives Tuesday.  I've booked a studio to spend a couple of hours to do my own 'critiquing'
And dude - I hope I can come back being your2IC.  The converted.  The learned.  Because then I'll be able to put my hand upand say "I had it wrong - but I finally have it right"
But lets see
There are too many people requesting mid options for me to think I'm the only one fucking it up.
Re: DT25 and midi
by animastereo on 2013-01-25 05:06:17.1170
And even if we are all wrong.... why so defensive?  Where are the Line 6 staff educating us???
Re: DT25 and midi
by animastereo on 2013-01-25 05:35:00.5590
Sorry.  Why AREN'T the Line 6 staff educating us.  It's their product/reputation/forum....
Re: DT25 and midi
by TheRealZap on 2013-01-25 05:36:50.7850
i'm not sensitive... i just don't care for people spreading misinformation....
especially people who have just admitted they don't even have the amp....
the reason for so many people asking is because of this misinformation and it's created a loop...
can there be a difference??? sure... the implementation is clearly different...
but they are also designed to be integrated...
the difference is so minor, that it's obsessive crazy to me how much effort people put into going around the integration...
you'd get more mileage or more improvement in your tone, by changing the nut on your guitar...
you can't simply turn on the amp in the store... expect all the firmwares to be at the right level... and all the settings squared away...
you can't simply dial the pod to the same amp and expect it to sound like the DT...
there are output modes, cabs, mic emulation, input z,mixer, panning, input selections,  etc etc loads of variables you aren't going to adjust in a store environment.
i don't expect you to come back and say you were wrong...
a famous quote for thought:
Look for the ridiculous in everything and you will find it.
Jules Renard
(1864 - 1910)
Line6 isn't here educating you because it's not what they do....
they provided you tools to make music, not a science project....
if you can't get a good useable tone... then it's the wrong gear for you....
if you insist on using midi, and doing some sort of cabling acrobatics... have at it....
I just think you'd be missing the point.
seriously i mean no offense....
i've just seen this argument time and time again...
and i'll never understand the point in bothering for 1:1 replication... when there's infinite options available that will sound farkin fantastic.
if the amp sounds better by itself to you... use however you want...
(it's all subjective anyway)
Re: DT25 and midi
by evilmikehoo on 2013-01-25 08:15:07.5630
Just think about what you just asked. Every new buyer comes on here with the same questions and expectations. Line 6 provided the learning tools. They can't provide one-on-one training for everybody that purchases equipment. These amps are only part of their line. Can you imagine what kinda staff would be needed? Can you imagine the cost increase that would hafta be absorbed by us? That's why they have this forum and it is serving it's purpose extremely well. All the answers and info are here, from the actual users and all of their unique situations and applications...if ya look for it. Granted, there are always new situations that may arise, but, basically, it's the same questions over and over. I was guilty of this myself until this realization set in. You need to have the amp and play with it to actually learn. If ya come up with a question, more than likely the answer is already here. I'm a newbie and definitely not a fanboy, but I absolutely love the product and thoroughly enjoy the learning process. When you're learning hands-on with enough info to point you in the right direction, you learn much more thoroughly, with enough additional knowledge to answer more questions yourself as they arise. Yes, Line 6 could provide more, but they don't. That does not take away from the product at all. Yeah, we ALL get frustrated, but just remember that frustration is part of the learning process. My suggestion is to browse thru all the forum topics whenever ya have the free time and see what ya can pick up from them. You'd be surprised! And you'll develope a newfound respect for those that hang here and help the newbies like me!!!
Re: DT25 and midi
by theoptimizers on 2013-01-25 11:12:02.6410
I'm sure it's frustrating for guys who have been on this forum for years, and have asked and answered these questions numerous times, to keep seeing newbies (like me) stick their heads in to ignorantly ask the same questions over again.
It's the nature of a board that lasts as long as this one has, for new people join and ask the same questions (with the same misconceptions) over again.
I for one I'm grateful for all of the information you experts dish out. And, I do try to find answers before I ask. But, it's not always easy to find them.
Anyway, thanks.
