Main :: POD X3
Pod x3 bean sound issue
by guitarajax on 2012-12-28 18:50:24.1560
I have had a Pod X3 bean for year but have only been using headphones and it sounds great.
But when i plug it into a studio monitor using the left 1/4 output jack it sound really quiet and not as good as the headphones did.
I have tested the studio monitor by pluging it into the headphone jack and it sounds great.
I have also tested it by plugging the headphones into the left 1/4 output jack and it again sounds really quiet and not as good as the headphone output jack.
Any suggestions? Am i doing something wrong or is the pod 1/4 ouputs broken?
Re: Pod x3 bean sound issue
by silverhead on 2012-12-28 19:48:10.5390
Check the Outputs Page 1. Make sure the output mode for the 1/4" Live Outputs is set to Match Studio / Direct. Then check Outputs Page 2 and make sure the Tone(s) you want to hear in the preset are On and panned appropriately.
by guitarajax on 2012-12-28 21:37:26.7230
Thanks for the quick suggestion but i figured it out after a few hours of messing around with it.
If i pull out the cable end just slightly from the jack it sounds loud and clear but if i push it all the way in it sounds quiet and like crap.
So i guess i will just leave the plug slightly out from the jack unless anyone else has had a similar issue and knows a fix or why its doing that.
