Main :: POD HD
My HD500 expression pedal doesn't work anymore
by colashanacogh on 2012-12-31 09:44:49
My expression pedal doesn't seem to work i have set everything up and assigned a pitch glide to the expression pedal but when i move it it justs stays at the same octave, this is my setup - http://imgur.com/xdaOy
Re: My HD500 expression pedal doesn't work anymore
by CairnsFella on 2012-12-31 18:40:15
Is your pedal toggled to EXP 1?
The pedal controls both EXP1 and EXP2 dependant upon the toe swithched being toggled. Check the light next to the pedal.
There are other possible causes, so I am not saying this is the problem... just one thing to check.
Also, aplologies, but a little worse for wear this morning so may not be being as clear as I imagine I am.
by colashanacogh on 2013-01-02 14:03:51
thanks for replying but the light is on ESP 1
by colashanacogh on 2013-01-03 13:24:36
anybody have a clue whats wrong maybe i need to reset to factory settings
by jimsreynolds on 2013-01-03 13:38:29
Try recalibrating the expression pedal.  Details are here --->
Expression Pedal Re-Calibration HD500  http://line6.com/support/docs/DOC-2223
