Main :: POD X3
Effects without an amp attached
by livinworship on 2013-01-01 08:41:09
I want to use just the effects on my X3 Live like the Wah but use the sound from my amp. I made a user patch with just Wah but the integrity of my sound goes away and is very noisy. Is there a way to use the pod like a stomp box effect?
Re: Effects without an amp attached
by knecke on 2013-01-08 05:08:55
what he said. can't find any answers to that problem.
by knecke on 2013-01-08 05:14:31
tried this?">">
by db0451 on 2013-01-08 07:26:32
Such a complex method is only necessary if you want to use FX send from your amp to create a more complex signal circuit that also includes your amp's pre-amp.
To simply use the X3 like any old stompbox that you'd plug into your amp, without worrying about that – which it sounds to me might be what you want – is very easy:
Just go into the Outputs settings and change the mode to one of the Amp In settings. This disables cabinet modelling – which may well be responsible for the bad sound you reported, as it's not a good idea to route one cabinet into another! Of course, make sure you also turn off amp modelling in your customised tones.
It's that simple!
