UX1 / Line 6 Driver Issues
by MarcTssf on 2013-01-04 09:03:27.0260
Hi guys,
I have a problem with my UX1 Driver.
I'm running Windows 7, with latest software updates etc.
In the 'Line 6 Audio-Midi' options panel, the driver refuses to run at anything other than 44100 / 16bit. In the advanced tab of the Sound Control Properties for the UX1 the Default Format is set to 24bit, 48000Hz but this has no effect on the Line6 Driver/Audio-MIDI panel.
How can I fix this? Has any one else had this issue and solved it? There's a few similar threads but no one seems to have any conclusive ideas.
Thanks in advance!
Re: UX1 / Line 6 Driver Issues
by silverhead on 2013-01-04 09:16:31.3630
There's the default value - and then there's the actual value. Seems to me that in this case the UX1's default value is being overridden by a value set wthin the application that the driver is communicating with (e.g. your DAW?). Check the application you are using the UX1 with and see if you can change it's value to match your UX1 default value.
