Main :: M5 / M9 / M13
Line 6 M13 version 2.04 won't store previous settings
by kelvin_wong on 2013-01-06 07:30:46.2350
I recently bought the Line 6 M13 (came with version 2.01) and I upgraded it to version 2.04.
Now my problem is the M13 won't store my previous settings.
For example if I set my "Blue Comp" settings and turn the knob to "Red Comp", then back to the "Blue Comp", my Blue Comp settings will be gone!
Any reason why?
Help!
Thanks!
Re: Line 6 M13 version 2.04 won't store previous settings
by phil_m on 2013-01-06 07:44:04.8570
That's just the way it works. You can't save default settings on the individual effect models. When you turn the model select knob, you bring up an effect model, and the settings that are saved with it are simply the factory defaults. Those can't be changed. This is the case even if you have it in autosave mode.
If you want to compare two different type of effects, the way to do it is use a different location on the M13, either in the same effect engine or in another one.
