Main :: POD HD
pod hd 500; looper volume
by bennialexander on 2013-01-07 12:47:32
hi all,
my looper volume, how do I set it?
When I use the looper, the problem is that the lead (when playing along needs to be a tad higher), but the looper volume seems it is not possible.
Ideas?
Kind regards.
Re: pod hd 500; looper volume
by silverhead on 2013-01-07 13:16:54
From the signal flow page, select the Looper. The display allows you to control the Playback Volume. Set it to less than 100%; experiment with the settings until you get the volume difference you want between the recorded loop being played back and your lead solo.
