Main :: POD 2.0, PODxt Family, Pocket POD, FloorPODs
Model pack on POD XT( not in use with turning button)
by Punkyboy on 2013-01-10 09:41:45.0320
Hello everybody!!
I buy 3 model pack for my POD XT,it's working great and allowed with license manager
But only if i use the computer to editing
So if i use the line6 edit all the packs appears on it
But if i turn on the "AMPS SELECT" button directly on the POD i don't see any NEW model pack in the little screen on the POD
I can NOT select a metal pack amp if i turn on the amp button of the pod
IS this Normal???
Am I obligated to  save my presets making with model packs if I want to use my POD without a computer
It's the same for the metal pack,fx,and classic amps
It doesn't appear  if i turn the fx button on the screen
Thank to help!!!
PUNKYBOY
Sorry for my bad english ,but i'm French!!
Re: Model pack on POD XT( not in use with turning button)
by Mr_Arkadin on 2013-01-10 10:44:48.8920
You should really use GearBox as this is the latest editor for the XT line. Download from:
http://line6.com/software/">http://line6.com/software/">http://line6.com/software/
by Punkyboy on 2013-01-10 13:09:49.3890
Thank you for your help
Do I Need to uninstall Line6 editor before???
My first post
is that I don't see the model pack amps on the lcd screen of the Pod when i turn the "Amps select" on the POD
Do Gearbox resolve that problem to refresh or update de firmware of the POD XT??
Because when i start the POd he's let see that all the packs are installed??
TX
by Mr_Arkadin on 2013-01-10 13:40:46.6540
Sorry, I misunderstood. I thought you were not seeing the amps in Line 6 Edit and were seeing them on the Pod XT - it seems that's it's the other way round. In any case you should still use GearBox in preference to Line 6 Edit.
Now to your problem. Have you run the Line 6 Monkey? It will update any drivers and programs you need. Also it sounds like you may need to run the licence manager again to make sure everything is authorised. Be sure to use the account that you bought the packs on otherwise it will delete the packs from your POD!
If you still cannot see your amps you may need to contact Line 6 Support directly:
http://line6.com/support/tickets/add.html">http://line6.com/support/tickets/add.html">http://line6.com/support/tickets/add.html
as they have the power to re-authorise etc.
by Punkyboy on 2013-01-11 07:32:38.9540
Hello
Now i see the amps on lcd screen ,aswell it's ok
BUT NOT THE FX JUNKIE goddamn lol!!!
I gonna try again to see if it's working
But let me thank you very much for your help and also for GEARBOX WONDERFULL man!!!
I was always thinkink how to use line 6 edit and the pod as a soundcard at the same time and nothing top do it doesn't work
Because i neede a usb and midi connection at the same time
But with GEARBOX it's wonderfull and working great
Thank you my friend!!
Now i gonna test it for the fx and as needed contast the support to say what happend!!
I let you know about in a few day's
Greeting!
by Mr_Arkadin on 2013-01-11 09:21:31.3990
You will not see the FX Junkie as these are not amps, so will not be on the amp button. The new effects appear in their respective effect slots, e.g. "FX-Killer Z"  will be in the "Stomp" slot, "FX-Bubble Echo" will be in the "Delay" slot etc.
by Punkyboy on 2013-01-11 13:32:33.6050
Hello
yeah i know that
But i mean that i not see the fx junkie effects when i turn the "EFFETCS "button??
The amps are ok now???
So i see al the normal  fx  like,phaser,tremolo.. but not the fx junkie are listing on the lcd screen of the pod?fx like hi talk
Or better explain if i look with Gearbox on pc i see al the fx listed in the "MOD"
but when i turn the effect button on the POD i don't see the fx junkie "mod"on the lcd screen
tx to help!!
All the drivers are updated with line monkey!!
by Punkyboy on 2013-01-17 12:20:46.0600
Hello
Finally i find the problem
I was always turning the Big Button"EFFECTS" on the pod and never see the fx junkie!!
You need to presse Stomp or Mod and double presse on it to edit after you turn the "EFFECT TWEAK" button and you can see the fx junkie listed
Thank you to help!!!
greetings
