Main :: James Tyler Variax Guitars
Support community for JTV.
problem with editor please delete thread I will repost
by Krontab on 2013-01-12 07:13:58.2510
Re: Hiss in modeled mode
by Krontab on 2013-01-12 07:16:55.8020
I thought I'd add that it is very present in the Class A-30 model with all dials at 12 O'clock
by silverhead on 2013-01-12 07:34:49.7970
Two questions:
- please clarify your first post. You say that hiss both is and is not present in modeled mode. Which mode is giving you the problem - modeled or mag pickups?
- how are you connecting to the HD500 - via VDI or 1/4"? Does it change anything if you switch?
by Benni2407 on 2013-01-12 07:49:45.9370
Which firmware do you use on your JTV? I had a problem similar to the one you describe and had firmware 1.71. on it. Changing to 1.81 helped.
But now I have to use the nwe acoustic models, which are not as good as the old ones...
regards,
Benni
