Main :: Line 6 Lounge
POD XT not recognized in Sonar X2A
by bengali on 2013-01-12 22:44:24
Hi there.  I have a new issue with my POD XT.  Not sure if it is fried.  My specs as follows:
Pod Xt
Windows 7
DAW- Sonar X2A
Processor- i7 2.67 GHz
64 bit
Soundcard- M-Audio 2496
Sonar X2A is not recognizing the POD.  The POD appears among the interface options in preferences but is greyed out and I cannot choose it.  So basically I cannot play guitar into my POD as I have done till recently.
Re: POD XT not recognized in Sonar X2A
by Triryche on 2013-01-15 12:02:32
If you run Monkey, do you have green ticks for drivers?
by TheRealZap on 2013-01-15 12:07:34
I've seen some DAWS do this, if they have a driver type setting...
for  exaample, WM, direct sound, MME, or whatnot...
you might simply need to select ASIO as the driver type and that would allow you to select the pod.
just a guess though...
