Main :: POD HD
Assigning effects to footswitches
by eyeguy24 on 2013-01-18 06:17:57.9370
I've created a patch where I have 8 effects that I want to assign to footswitches 1-8.  However, if I have the HD 500 configured so that I choose different patches with footswitches 5-8, I cannot access my effects that have been assigned to those footswitches.  On the other hand, if I configure the HD 500, so that I can access effects assigned to footswitches 5-8, I can not easily access different patches, if I want to change during the song I am playing.  So, my question is, is there a short cut that exists so that I can easily use footswithces 5-8 for both pathes and effects?  Thank you in advance for all of your thoughts and ideas.
Re: Assigning effects to footswitches
by phil_m on 2013-01-18 06:41:30.2220
You have to choose pedalboard mode or preset mode in the setup menu. In pedalboard mode, to select the preset you want to go to, you have to hit the bank up or down switch, and then you can use switches 5-8 to choose the preset you want. Other than that, there's no quick way to switch between the two modes.
by JimKidd on 2013-01-18 06:44:11.1160
From my own experiance, it's either one or the other.
What you could do is decide which effects you really want to toggle on and off and assign foot switches 1-4 to those.
by silverhead on 2013-01-18 07:10:30.9230
No can do. There is no mind-reader beneath the switches to determine which behaviour you would prefer at the moment. And any physical method (even double-tapping) of distinguishing would probably create havoc with the precise timing needed for these changes during the middle of a song.
Short story - you need to choose one or the other behaviour.
by eyeguy24 on 2013-01-18 13:19:19.3900
Yes, this is what I've been doing, but of course there is always an extra effect that I want to toggle...
Thank you for your reply.
by eyeguy24 on 2013-01-18 13:20:18.6860
You'd think they could develop a mind reader...
Thank you.
by eyeguy24 on 2013-01-18 15:20:04.7820
I just thought of this.  I could assign patch into 1A with effects 1-4.  Then duplicate it into 1B with effect #5 just turned on.  Not assigned to a footswitch.  Then I could toggle back and forth between the 2 patch locations.
by JimKidd on 2013-01-18 16:12:40.7890
That's a good idea
by silverhead on 2013-01-18 16:25:34.5500
There will be a momentary interruption in FX 1-4 as you switch patches. During the switch they will be turned off, and then on again. This may be noticeable for time-based FX such as delays.
by CairnsFella on 2013-01-22 17:29:57.3560
From memory (which is somewhat muddled nowadays, so my apoogies if it proves incorrect) you can assign more than one effect to each pedal. In that case you may be able to group the effects to some degree if there are any combinations that you tend to select / deselect at the same time.
