Main :: M5 / M9 / M13
Noise suppressor info
by alexispareja on 2013-01-18 08:20:50.2960
How can I keep a noise suppressor active without haveing it take up a footswitch or bank? I just need something light to get rid of hum and that it doesn't get in the way of the dynamics.
Thanks
Re: Noise suppressor info
by phil_m on 2013-01-18 11:25:43.2630
I'm not sure what pedal you're talking about, but the noise gate works the same in all of them. If you go to the setup menu, you'll see the noise gate parameters (threshold and decay). Turning the threshold parameter up turns the noise gate on. This setting is saved with the scene then. If in manual save mode, you'll have to re-save the scene to save the noise gate setting. This noise gate will allow to use noise suppression without having to use up and FX slot.
by alexispareja on 2013-01-18 22:17:41.7360
Sorry yes it is the m13. I haven't tried that function cause I wasn't sure where it was located. Thanks this should do the trick.
