Pod farm 2.5 and pod x3 live, problem
by sullibass on 2013-01-19 11:28:01
Hi
i wanted to use the pod farm with my pod x3 live that i have connected thu usb
standalone and vst
but i have the following problem
i have selected the audio interface POD X3 LIVE in preferences of the podfarm
and i have connected the guitar into the input of the x3 and the outputs of x3 to the monitors
the problem is that i hear the sound of the guitar processed by the settings of the patch i have selected in the x3 an then processed in  the pod farm
so, if i have a clean sound in the pod farm but i have a preset in the x3 whith overdrive or whatever it sound doublely processed
i want it to be processed ONLY by the podfarm
do i have to do a plain sound in the x3 for it?
or there is a way to inhabilitate the x3 processing meanwhile i use podfarm?
thanks
ESPAÑOL:
Hola
quiero usar el podfarm con mi pod x3live conectado al usb
tanto en standalone como en vst
pero tengo el siguiente problema:
tengo seleccionado en las preferencias del podfarm el x3 live como interfaz de audio
y tengo conectada la guitarra al input del x3 live y sus salidas a los monitores
el problema es que oigo el sonido procesado por el patch que tengo en el x3 live y luego procesado por el pod farm
y yo solo quiero el sonido del podfarm,
asi que si por ejemplo tengo un patch limpio en el podfarm pero overdrive en el x3  o lo que sea, suena saturado y con los ajustes del x3,
he de hacer un sonido plano y limpio para usar el podfarm?
o hay alguna manera de inhabilitar el procesado del x3 mientras uso el podfarm, apara oir solo este ultimo?
gracias
saludos
Re: Pod farm 2.5 and pod x3 live, problem
by TheRealZap on 2013-01-19 11:34:14
you can't use pod farm standalone with an x3 use gearbox.
you need to have the line6 drivers installed (no asio4all)
by sullibass on 2013-01-20 09:58:04
yes, i have the drivers installed
gearbox works fine
i suppose i'd better use podfarm with my daw and mi other audio device
is that correct?
by silverhead on 2013-01-20 10:04:16
Yes. With the X3, Pod Farm works as a plugin to your DAW.
by sullibass on 2013-01-20 10:30:15
ok
thank you, i´ll see
i want to see if the current sound in the x3 affects the plugin
