Main :: POD HD
how can I quickly dial in FX parameter values
by Gerritsmrg on 2013-01-23 03:33:59.9770
Since my last update of my PODHD500 (flash memory 2.10) quick clockwise turning of knob 4, to dial in a higher value of an effect parameter, results in lower values or even zero. Does anyone have the same problem? Or better, is there a way to avoid this other than just slow dialing?
Re: how can I quickly dial in FX parameter values
by jimsreynolds on 2013-01-23 03:37:27.7450
There has always been 'acceleration' on the POD knobs ... the faster you turn them, the larger the change of values.  Don't forget you can also set most values directly using HD Edit if it really gets your goat.
by Inerzia on 2013-01-23 05:19:03.9750
That's the intended knob behavior, Gerrit.
Maybe it takes a little time to get used to, but it works fine for me though.
by Gerritsmrg on 2013-01-24 06:00:04.9870
im my case the parameter value goes in oppisite direction
by Gerritsmrg on 2013-01-24 06:02:44.7580
I don´t think so, the parameter goes in the opposite direction, or better: always toward lower values. I am beginning to susspect it is a problem of my POD (the switch FS1 also has difficulties......
by Inerzia on 2013-01-25 03:19:59.3760
Then yeah, you probably have a problem with your pod.
Don't know about FS1, but the other problem could be due to a faulty firmware update.
Have you tried reflashing it?
