Main :: POD HD
Looper not sounding right.
by kstarks1 on 2013-01-25 08:50:16.3940
Hi all, I have the HD500 and have a question.  When I use my external stomps connected through the fx send and return all is good, however when I start using the looper it starts sounding mono like.  Any ideas on what I might have screw'd up?
Re: Looper not sounding right.
by phil_m on 2013-01-25 08:54:23.4350
The looper is mono, so if you have a stereo separation going into, it will sum it to mono and then the recorded loop will be played back as dual mono.
by kstarks1 on 2013-01-25 09:02:19.3780
How should I correct this?
by phil_m on 2013-01-25 09:27:07.9050
Depending on how you're using the looper, you could put it in pre position, and then you could still maintain a stereo separation after the looper. But if you're looping sounds where you want to use different effects, there's really not much you can do.
by kstarks1 on 2013-01-25 09:37:54.2120
Thanks for the help Phil !
