Main :: POD HD
HD Pro and FCB 1010 midi control
by dschaaf on 2013-01-26 12:07:05.4860
I have a FCB1010 to use with my HD Pro and I'm wondering if it is possible to use the footswitches as simple toggle on/off of the effects. If so, is there a static value for say a "distortion" block that I would assign in the FCB1010?
Where can I find a listing of the midi cc values?
Thanks,
D
Re: HD Pro and FCB 1010 midi control
by spaceatl on 2013-01-26 22:46:55.9490
CCs are at the end of the Advanced manual...
http://line6.com/data/6/0a06434d11951507ddd9b9d817/application/pdf/POD%20HD%20Pro%20Advanced%20Guide%20v2.10%20-%20English%20(%20Rev%20A%20).pdf">http://line6.com/data/6/0a06434d11951507ddd9b9d817/application/pdf/POD%20HD%20Pro%20Advanced%20Guide%20v2.10%20-%20English%20(%20Rev%20A%20).pdf">http://line6.com/data/6/0a06434d11951507ddd9b9d817/application/pdf/POD%20HD%20Pro%20Advanced%20Guide%20v2.10%20-%20English%20(%20Rev%20A%20).pdf
by jimsreynolds on 2013-01-27 05:07:18.3370
Just remember, assigning a controller footswitch to toggle a  POD FX Block on/off is a two step exercise.
1)  Assign a footswitch within the HD Pro to toggle the effect on/off that you want to control.  Of course there is no physical footswitch on the HD Pro but you can still do it within HD Edit.  Details in the advanced manual or here --> http://line6.com/support/docs/DOC-2721">http://line6.com/support/docs/DOC-2721">http://line6.com/support/docs/DOC-2721
2)  Assign your midi controller pedal to send a Midi CC to toggle the required 'footswitch' on the HD Pro.   e.g. Midi cc 051 controlls FS1.  You can send any value within the cc  message  to the POD and the footswitch will toggle.
by dschaaf on 2013-01-27 05:13:50.3340
Thanks!
by dschaaf on 2013-01-27 05:14:14.4400
Excellent, thanks Jim....exactly what I was after!
