Main :: POD HD
Please Help with JTV controlled by pod hd500.
by sonas on 2013-01-29 04:35:54.1210
Hi
I really need advise in the most simple language ( Im not a tech guy) how can I get the pod 500 to controll my JTV 59 on a preset by preset basis. I mean change tunings,,,modles..magnetic pick ups. I would like one acoustic patch with half tone down. An electric preset also half tone down, with modled electric. And one preset with mag pick up from the jtv
Im begining to slowly sort out what I need to know, this information would be a hughe help.
All the best
Sonas.
Re: Please Help with JTV controlled by pod hd500.
by Rewolf48 on 2013-01-29 05:33:09.8210
Read the HD500 Advanced Guide starting at Page 2.11, get a proper VDI cable and play with it until you understand how it works.  It is really simple and there is no point copying the content of the manual.
http://uk.line6.com/data/6/0a06434dfb244f7b7f489af64/application/pdf/POD%20HD500%20Advanced%20Guide%20v2.0%20-%20English%20(%20Rev%20A%20).pdf">http://uk.line6.com/data/6/0a06434dfb244f7b7f489af64/application/pdf/POD%20HD500%20Advanced%20Guide%20v2.0%20-%20English%20(%20Rev%20A%20).pdf">http://uk.line6.com/data/6/0a06434dfb244f7b7f489af64/application/pdf/POD%20HD500%20Advanced%20Guide%20v2.0%20-%20English%20(%20Rev%20A%20).pdf
by sonas on 2013-01-29 05:49:33.4570
Sorry I cant make herâd nor tail of that. I have the online manual I just need a clear description. I have a VDI cable.
Thanks
Sonas
by ajktsb on 2013-01-29 06:17:20.6490
For me, the easiest way is make my presets using HD EDIT. On the mixer tab you will see a couple of drop down menus that let you choose your model of Variax and another that lets you choose the model you want. You also MUST choose the option that says "FORCE" Variax to use this model. I am not at the software now so I don't remember the actual syntax. Then once you save that preset on the HD it will pull up the model you want when you choose that preset. Works great!
by sonas on 2013-01-29 06:25:53.7680
Thanks Ill try that
Sonas
by sonas on 2013-01-29 08:16:15.4990
It works but only when I have the tuning know on the guitar tuned down half a tone, do I have to set it to locked or something like that.
Sonas
by ajktsb on 2013-01-29 13:14:45.6780
No. You should be able to store your tunings the same way as you store the model and Variax information. Make sure you've looked at all the options and have them set the way you want on EVERY patch.
