Main :: StageScape M20d Mixer Community Support
How to Add Icon to Gallery?
by silverhead on 2013-01-30 07:30:57.1690
I have customized a factory preset and used the 'Save As...'  feature to add it to the list of presets. I can see it in one of the 'More' sub-folders at the far right of the Stage Icon Gallery. But I can't see how to make it appear individually in the Gallery as opposed to in the More folder. I would like to be able to see it andf mark it as a favorite for easy access in future setups.
Removal of icons from the Gallery is specifically covered in the Advanced Guide, but not addition (as far as I can tell).
Re: How to Add Icon to Gallery?
by ArneLine6 on 2013-01-30 07:33:03.7560
To add a preset to the Icon Gallery you just drag the stage icon into the Gallery.
by silverhead on 2013-01-30 07:34:28.6520
I can add it to the Stage, and then drag it down to the Gallery strip, but when I try to Drop it there I get a message saying that the preset already exists (which it does) so I would need to rename it first - but I already did that when creating it. It seems that if it is already in the preset library it can't be added to the gallery??
by silverhead on 2013-01-30 07:46:18.3040
Here's a recipe that ilustrates what is happening:
1) Create a new Setup - empty stage.
2) Drag any icon from the Gallery onto the stage.
3) With the icon selected, hit TWEAK
4) Hit the Folder icon to the right of the Channel Name in the top left strip
5) Select Save Prest As... and give it a new name
6) Hit Setup to return to the stage view
7) Drag the newly-named icon to the Gallery.
8) Observe the error message. The icon does not stick to the Gallery.
What am I doing wrong?
by ArneLine6 on 2013-01-30 07:48:16.5620
Yes, saving it to the Gallery saves it also in the preset Library. If the name already exists you get this warning. You could either rename it in the Library or on the Stage and then drag it to the Gallery.
by ArneLine6 on 2013-01-30 07:51:43.5840
To be clear, if you rename the preset in the library and then go to the stage and drag the icon to the gallery the preset is already existing (you just created it)
Try just renaming it on the stage and dragging it to the gallery.
by silverhead on 2013-01-30 07:52:36.9250
OK - I was able to save it to the Gallery. Thanks.
