Main :: POD HD
POD HD PRO FIRMWARE UPDATE NOT RESETTING TO FACTORY
by NeedmoreCrunch on 2013-02-05 11:25:53
I just attempted (twice) to restall my firmware to factory using Line 6 Monkey, it goes through the motions even asking if I want to keep my custom patches (which I selected "NO").  The firmware goes through the motions and all my custom patches and settings remain.
Explain?
Re: POD HD PRO FIRMWARE UPDATE NOT RESETTING TO FACTORY
by silverhead on 2013-02-05 11:30:09
Are you running HD Pro Edit while updating the firmware?
by NeedmoreCrunch on 2013-02-06 08:20:59
No, just line 6 monkey.  I had to roll-back to an older firmware version then re-update to the latest version to get the user patches removed, but some user info still remained.
by silverhead on 2013-02-06 09:54:38
If the old user info that remained is the Setlist names, you need to reset the global parameters and then recalibrate the pedal (both of which should always be done after a firnware update/reinstall).
http://line6.com/support/docs/DOC-2222">http://line6.com/support/docs/DOC-2222">http://line6.com/support/docs/DOC-2222
http://line6.com/support/docs/DOC-2223">http://line6.com/support/docs/DOC-2223">http://line6.com/support/docs/DOC-2223
by NeedmoreCrunch on 2013-02-10 08:34:16
POD PRO... not 500.  But the left arrow during boot did reset my set lists.  Thanks.
