Main :: DT50/DT25
DT25 head will not start up
by benbutterworth on 2013-02-05 15:21:50.7520
I have a DT25 head, which worked fine the other day, after upgrading to the 2.0 update. I turned it on today and it doesn't work. The power light comes on, the panel is lit, however no switches change their settings e.g. topology, channel A/B, class A/AB.
I have tried restarting the amp and pinching the class A and topology settings. This resets the amp, I believe, I hear some physical clicking inside the amp, but the swithcing does not work on the front.
This problem occurs whether plugged directly into the amp or via L6 link fomr my HD500.
Any thoughts? I have a gig soon!
Thanks,
Ben
Re: DT25 head will not start up
by spaceatl on 2013-02-05 21:39:55.2300
Perhaps the flash did not complete successfully...Have you tried to flash the amp again?
by benbutterworth on 2013-02-07 02:53:55.3370
I haven't tried that yet. I will give it a go.
What is odd is that I have used it since the update. I'll let you know how I get on.
by benbutterworth on 2013-02-07 16:12:17.4460
Reinstalled current firmware, it worked a treat! Thanks!
