Main :: Relay Digital Wireless
Relay g50 with beyerdynamic TG L55.
by Funkoff on 2013-02-22 03:48:20.9950
Hello! I have the Relay g50. Can i use condenser micorphone beyerdynamic TG L55 with Relay g 50.
TECHNICAL SPECIFICATIONS for TG L55:
http://eastern-europe.beyerdynamic.com/shop/media//datenblaetter/DAT_TGL55c_EN_A2.pdf">http://eastern-europe.beyerdynamic.com/shop/media//datenblaetter/DAT_TGL55c_EN_A2.pdf">http://eastern-europe.beyerdynamic.com/shop/media//datenblaetter/DAT_TGL55c_EN_A2.pdf
Re: Relay g50 with beyerdynamic TG L55.
by dboomer on 2013-02-22 10:46:21.0730
Yes, but you will need to rewire the plug (see documents section)
Are you certain that the mic's specs will work with your application?
by Funkoff on 2013-02-24 09:07:47.2780
Signal is very low. Don't work/
by dboomer on 2013-02-25 15:56:50.5600
That's what I meant about the mic's specs.
by sdevino on 2013-02-28 08:44:07.3040
Did you rewire it?
by Funkoff on 2013-03-05 22:35:05.7290
Yes, I did. Obviously nominal impadance on mic very high(1 kΩ).
