Main :: Vetta
Vetta 2 patch retention
by bhayesl6 on 2013-02-25 10:36:40
Hi.
I recently bought a secondhand vetta 2 combo and I have two questions about the operation of the amp.
I've noticed that when the combo is switched back on after about 20 mins it is set to a higher bank of patches than that set before it was switched off.
Also, the display panel needs to be tapped lightly before illuminating.
Do these suggest a problem with the amp? Is it a simple matter to resolve?
Thanks for your help.
Brendan
Re: Vetta 2 patch retention
by DickFoster on 2013-02-26 08:47:26
It sounds as if it may be ready for a new battery. The display problem is probably just a loose connector. It should be easy to put it all right. Replace the battery and then wiggle and press the connector home on the display board a couple of times.
Yes, you'll have to take it apart so if you're not comfortable doing that, find a friend who's comfortable digging around the bowels of PCs and such to give you a hand.  You'll need a new CR2430 3V lithium battery.
by bhayesl6 on 2013-02-26 10:56:14
Thanks for that info. I'll give it a go and revert back.
