Main :: POD HD
Parallel effects loop and the 4-cable method
by lou_kuehl on 2013-02-27 10:35:51.9210
Hello,
Is the 4-cable method pointless when using parallel effects loop?
Re: Parallel effects loop and the 4-cable method
by phil_m on 2013-02-27 10:53:08.3540
Short answer: yes. Long answer: probably.
The problem with using parallel loops and digital effects is that you really need to have a "dry kill" feature in order for them to work correctly. This isn't available on the HD500 (or whatever POD you're talking about).
