Main :: JM4 Looper
Is there a way to add new drum samples? (drum loops) (internal memory) (edit memory)
by janaleks on 2013-02-28 16:48:37
It would be great if you could for example create a drum loop file in a music program. Then export it and place it in the internal memory of the jm4 . The idea is that they would work like those drum loops that the jm4 already has. That way the user could see the count in and manage them in the same way as those from factory.
Does anyone have a clue on how would it be done?
Thank you!!
Re: Is there a way to add new drum samples? (drum loops) (internal memory) (edit memory)
by cleitontortato on 2013-03-04 14:52:21
Hi Janaleks,
I'm new here and I want to do the same thing with my JM4.
I just post because I want to receive a update if someone of Line6 Team answer this.
[]s
Cleiton
