Main :: POD HD
Problems updating flash on Pod HD Desktop, please help
by claytonjford on 2013-02-28 21:44:28.0920
I've been unsuccessfully trying to update the flash on my Pod HD Desktop using Monkey.
I have tried the following:
  • every USB port on my laptop
  • every flash update version (I'm currently on 1.33 and I'm trying to get to 2.10.
  • tried both the regular update and the "update from file" option in Monkey
When ever I attempt the update I get the message "Pod HD update failed. (Code 80007211) Firmware update timed out waiting for response from the device. Try the update again making sure the cables are still connected". See the picture attached.
If I turn off the Pod and back on again it just comes back to normal.
However everything else works fine, I can record via the Pod into my computer, I can change patches via Line 6 Edit etc etc.
Any help would be greatly apreciated.
Thanks
Clayton
Re: Problems updating flash on Pod HD Desktop, please help
by claytonjford on 2013-02-28 23:03:38.2220
As an update I've also tried doing the update in safe mode, and in flash update mode. Still no luck.
by toneman2121 on 2013-03-01 07:45:02.4220
the only thing i can think of is to re-install the drivers
by spaceatl on 2013-03-01 08:59:12.0380
Update from file is doing the same thing?
by claytonjford on 2013-03-01 22:16:06.8770
Yep update from file does the same thing, and I just tried reinstalling the drivers. Still no luck.
I'm going to try it on a friend's computer when I get a chance.
