Main :: POD HD
Switch between tube amp's preamp and POD HD Preamp models?
by gb1382 on 2013-03-01 10:36:01
Brand new here. Please forgive my greenness.
I have a really nice tube amp with a serial effects loop. use the POD HD PRO unit in as versatile manner as possible.
I want to be able to use either my amp's preamp, OR the pod's preamp models, depending on the patch. Is it possible to set up so that I can either bypass my amp's preamp, using the Pod's preamps directly into my poweramp and have access to all the Pod's effects in their proper place (pre/post HD preamps), AND also have the ability to switch off the pod's preamp modeling, use my tube amp's preamp, while still being able to put all the pod's effects in their proper place in the chain (pre/post tube preamp)?
I hope I explained that correctly...
Thanks for the help.
Re: Switch between tube amp's preamp and POD HD Preamp models?
by dbagchee on 2013-03-01 14:50:17
Short answer is yes. Long answer is here
http://line6.com/support/thread/74159
">http://line6.com/support/thread/74159">http://line6.com/support/thread/74159
by gb1382 on 2013-03-02 00:26:13
Awesome! Thanks a lot for the link, man. I appreciate it.
by jimsreynolds on 2013-03-03 06:15:12
Yep, checkout this primer too if you want to get your head round it a little quicker.  http://line6.com/support/docs/DOC-2522">_jive_internal="true" class="loading" href="/docs/DOC-2523" title="http://line6.com/support/docs/DOC-2523
">http://line6.com/support/docs/DOC-2523">http://line6.com/support/docs/DOC-2523
