Main :: POD HD
My recently purchased POD HD500 sounds awful
by jetsetRM on 2013-03-02 10:36:25.5070
So I had just purchased my HD500 not 24 hours ago, and I've got to say, it sounded pretty good through my Spider 3 amp.
Here's where the problems start. When I first plugged it into my computer and audio interface, I noticed the volume is VERY VERY LOW. I cranked up the volume on the AUX IN for the inputs, but it's still far too quiet. So naturally, I turn the channel volume up on the HD500. It's louder, but has far too much gain. Still not loud enough. Finally, I crank up the master volume on the HD500. I'm talking up 100%. Finally the volume is "manageable", but that high gain sound won't go away. It's still not the volume I should be expecting out of my KRK Rokit 5's.
The audio interface I'm using is the M-Audio Profire 610. Here are some pictures linked to show you how I'm wiring it.
Can anyone help me out here? When I was watching this video, I replicated the EXACT sound when he makes a new preset starting at 3:00. He just made a new preset with the "Treadplate" amp default and it sounds amazing from the start. When I try replicating that sound, It sounds more like I'm plugged into one of those tiny portable amps.
I'm at work right now, but when I get home, I'll post a screencap of my settings on the HD500 EDIT for reference.
Re: My recently purchased POD HD500 sounds awful
by spaceatl on 2013-03-02 11:08:29.5690
check the switch on top of the HD500 is set to line...using unbalanced 1/4 cables...Also, make sure the output mode is studio direct...
by bjnette on 2013-03-02 17:38:27.9280
And to minimize the high gain noise turn the aux input from default to aux or variax.
by jetsetRM on 2013-03-03 19:40:40.6460
Setting it to "line" definitely helped with the clarity of the sound, but still far too quiet.
The output mode was set to studio direct initially.
