Main :: POD 2.0, PODxt Family, Pocket POD, FloorPODs
Hi... Is it possible to use Floor POD Plus as a controller in POD HD?
by tonyalbert on 2013-03-04 21:00:55
I used analog pedals  for a long time and I'm getting to grips with the digital practicalities.
Thanx!!
Re: Hi... Is it possible to use Floor POD Plus as a controller in POD HD?
by Mr_Arkadin on 2013-03-05 05:04:01
Well not directly. The only way you could use it is via a computer as the MIDI on the HD only works via USB. Also you would have to map the MIDI CCs to the HD functions. I have no idea how difficult or easy that is (or if it's even possible).
Personally the FBV Express controller is a lot easier and can be had cheap second-hand if you don't get the latest MkII version. You could sell the Floor Pod Plus to offset this cost - I doubt you'll use the sounds after hearing the HD versions.
by tonyalbert on 2013-03-08 12:30:59
Ok man. Thanx!!!
