Main :: FBV MkI / MkII Controllers
FBV MK II Express can't connect to computer via USB
by Dijjy on 2013-03-08 11:24:26.3340
Hi
Just bought new FBV Express MK II and the computer (windows 7) doesn't load the device. There is no signs of life on the FBV either (no lights)
Have I got a broken one?
I'm used to the slightly bizarre Line 6 monkey  because I also use the Line 6 UX1. The monkey or FBV software can't 'see' the device either.
I've tried various USB cables.
Help!
Dij
Re: FBV MK II Express can't connect to computer via USB
by TheRealZap on 2013-03-08 14:48:57.3960
you probably need to install the drivers: http://line6.com/software/">http://line6.com/software/">http://line6.com/software/
you can get them and install them without using monkey.
by Dijjy on 2013-03-09 06:49:58.8080
Hi
I've downloaded the FBV control software - but there is still no response.
The device just doesn't 'boot up'.
I can't find any other driver software. If you search for a driver for the FBV Express the search engine just returns a 'at this time, there is no software available that matches your selection'.
Would you be able to point me in the right direction where to find a driver? ( a file path would be much appreciated!)
Many thanks for your help - it's appreciated.
Dij
by fflbrgst on 2013-03-13 05:36:52.2540
Are you trying to use the FBV for MIDI control (that's what the Control software is for) or do you have a device (like a Spider IV amp) you are trying to control?
The only other software update for the FBV is the Flash memory update.
Have you tried a different USB port?  If your computer doesn't 'see' the FBV when you have it plugged in, then it is indeed not working.
