Main :: James Tyler Variax Guitars
Support community for JTV.
Jtv latency
by Lurotex on 2013-03-10 04:04:31.9980
Hi everyone of you,
i'm playing my jtv69 but i feel a little of latency when playing with strong alternative tuning such as 1/2 down.
nobody notice the same thing?
Bye
thanks
Re: Jtv latency
by snhirsch on 2013-03-10 06:45:09.2020
A tiny bit of latency is inherent in the pitch-shifting algorithm.  I find it helps if you cannot hear the acoustic sound from the guitar (i.e. amp turned up or headphones).  The lag is much more obvious when you can hear the mechanical noise from the pick attack.
In rehearsal or stage situations, it really isn't too bad.
Re: Jtv latency
by moondancer on 2013-03-11 08:45:02.8870
I'm a owner of the JTV 69 since November last year and before I tested the guitar I was no friend of modeling instruments.
But I must say I'm really astonished and happy with the very little latency. I use it for sliding, Drop D, as a capo etc.
I felt he latency is in each tuning a little bit different, e g. capo 3rd fret, where in my practice I found the longest delay, but still acceptable.
Yes, and as snhirsch wrote, keep your amp loud enough and try also different models, because I felt that also the modeling of the guitar
has a little influence on the latency.
Have fun.
Edgar
Re: Jtv latency
by bigglesdog on 2013-03-11 13:07:25.9720
I don't notice the lag when just playing, but I do when trying to record with Pro Tools to existing tracks. I have to compensate slightly in my playing style
Re: Jtv latency
by phil_m on 2013-03-11 13:43:45.9370
Are you saying that the latency is coming from monitoring through Pro Tools or from the Variax itself?
Re: Jtv latency
by Lurotex on 2013-03-11 15:16:14.4840
i notice this too...when  playing direct in an ampli it is just a little latency (that sincerely i think it can be eliminated with a dual-core cpu and a little software optimization) but when i used it into a digital software such as TH2 it increase much more.
Re: Jtv latency
by clay-man on 2013-03-11 18:40:13.4380
Trust me, pitch shifting ALWAYS will have latency, or else it will sound like complete garbage. It's impossible to pitch shift without running a bit of the signal through the algorithm so it can figure out what to do with it.
If it was real time, it would literally not work at all.
I swear they said they killed off a lot of latency though. In a video with Rob Chappers, a Line 6 rep said they have 0 latency, but I guess that's not the issue. I was skeptical myself, because like I said, pitch shifting will ALWAYS need latency.
It does NOT matter if your processor was the speed of light, a processor can't see into the future, so it needs a bit of the signal to calculate the pitch.
Remember, pitch = frequency = time, ergo it needs time to calculate.
example:
/.........\___/
123456789
That's a sine wave, the width represents the pitch, as it does represent time. You need time to read the wave, ergo it needs 9 MilliSeconds to see the whole pitch. The longer the latency, the cleaner the tracking, but we usually deal with a short frequency range, so we don't need the latency to be that high.
In short, Processing power will not help the latency.
Also someone mentioned that if your audio interface is having latency, that will tax even more latency onto everything.
