All Activity
- Past hour
BillyL joined the community
jgodoy2618 joined the community
leunam123 joined the community
alsugar joined the community
gabii_1209 joined the community
takayasuzuki joined the community
idll joined the community
PPTKDan joined the community
- Today
marcos8057 joined the community
hannahwalters joined the community
Spider V 30 MKII replacement speaker suggestions
Bill-Hanna replied to teagueAMX's topic in Spider V
I have a couple thoughts for you to consider: This is a good video from YouTube where user that has replaced the speaker in his Spider V 20 MKII. Just remember the Speaker is 4 Ohms' My second thought is to use the 4 Band Semi Parametric EQ shape the tone to your liking. Another good video from YouTube. Hope this helps. Bill -
Lindaereda started following market place purchase
HX Stomp Left/Right outputs always plugged into on board junction box...
rd2rk replied to johnnygomezmusic's topic in Helix
Your description of the signal chain sounds like the Vertex "Stereo" wiring that you get when you scan the QR Code. In terms of physical wiring that's pretty straight forward, with the addition of the L/R from the last "Time Based Effect" being connected to the HXS L/R Inputs and the HXS L/R Main Outputs connected to the Vertex L/R Inputs and on to the amps. If I've got that right, then apart from defective cables, that leaves the internal routings of the patches in the "Time Based Effects" and the HXS. Check the patches in the H90 and Big Sky to be sure that they are outputting on both channels. Remember that unless ALL blocks in the HXS signal chain are stereo (or the Path is SPLIT and recombined, in which case BOTH the A and B paths will be STEREO and can contain stereo FX) the signal will be summed to MONO. Check any SPLIT and MIX points for panning issues. Attach a copy of the preset that you want to use (the client's original? NOT a screenshot!) so that we can have a look at it. -
Thank you! I’ll give it a go.
- Yesterday
helix lt with power stage SD 170 into an 2x12 celestion V30 harley benton
datacommando replied to sgrain's topic in Helix
Hi, Now, I’m really confused? Are you the same guy who started this thread? After a year, you now find that you cannot create a good tone using the Helix LT with the SD PS 170 and a 2x12 cab. You don’t tell us in what scenario you using, or intend to use, this set up - studio, live, bedroom? As I stated way back in your previous thread about comparison with YouTube videos - “if you are not using the exact same guitar, strings, technique, play back system, monitors and listening environment what do you think it would sound like?” Much like you, in here we are constantly confronted by young people who cannot even get close to the sound of guitars that are present in YouTube demos. My guess is that what you are missing is the skill to figure out how to make it sound good. You need to tell us what it is that you want to achieve. Hope this helps/makes sense. Oi, Agora estou realmente confuso? Você é o mesmo cara que iniciou esse tópico? Veja o link acima. Depois de um ano, você descobre que não consegue criar um bom tom usando o Helix LT com o SD PS 170 e uma cabine 2x12. Você não nos conta em que cenário você usa, ou pretende usar, esse cenário - estúdio, live, quarto? Como afirmei no seu tópico anterior sobre comparação com vídeos do YouTube - “se você não estiver usando exatamente a mesma guitarra, cordas, técnica, sistema de reprodução, monitores e ambiente de audição, como você acha que soaria?” Assim como você, aqui somos constantemente confrontados por jovens que não conseguem nem chegar perto do som das guitarras que estão presentes nas demos do YouTube. Meu palpite é que o que está faltando é a habilidade de descobrir como fazer com que pareça bom. Você precisa nos dizer o que deseja alcançar. Espero que isso ajude/faça sentido. -
I there guys . let me tell you about my nightmares. Now I'm 51 years old, when I was 20 I had a garage band and used a jcm900 mkII connected to 1960 A with a Yamaha rgx 312 guitar, for effects I used the zoom 505 with a boss EV volume pedal to do wha wha.than the band ended … and I stopped playing and sold everything, after a few years the fever returned and I started by buying a telecaster and a fender reverb 25 amp, in the meantime I bought a strat and an epiphone les paul with which I have been playing more, for now One year I purchased a Helix LT, a Seymour Duncan PS 170 and a 2x12 Harley Benton with V30 Celestion . I'm about to give up, because I still don't get good sound from this set, what am I missing??? Does anyone have this set that can help me?Not even the factory presets sound god... what is missing??? best regards from Portugal
Hey all! I'm working on a rig for a customer that has the HX Stomp with a Vertex Interface on the board. Basically, Left/Right outputs are always plugged into the interface's L/R inputs that go out to the two amps/DIs. After reaching out to Vertex, using only the LEFT out of the interface sums both outputs for mono operation. I know that the Stomp itself sums stereo effects to mono when plugging into just the left output, but in this case, they're always plugged in and the summing happens at the interface. Here's the quirk: customer had a patch with an amp/cab block and legacy plate reverb. I turned off the amp/cab block because I was plugging into an amp. Using the left output of the vertex interface, I was only getting reverb with little to no dry signal. plugging into the right output on the interface had dry signal plus reverb. so I removed all blocks to test. left output on the interface has nothing and right output has dry signal. while plugged into the LEFT output, panning either direction at the output block did nothing. while plugged into the RIGHT output, panning fully left muted everything and panning fully right was dry signal back again. I have tried several settings and variations but can't seem to figure this one out after a few hours. any input to give me new perspective/something else to check out would be immensely helpful! chain is: GTR > Interface Tuner Fender Switchboard with 4 drive pedals, out to H90 stereo BigSky stereo HX Stomp stereo, back to interface Thank you! jg
Awesome! That sounds ideal--thanks for your reply!
I would use the 4 Cable Method (4CM) as described in the HX FX manual, in the ’Hooking It All Up’ section. This allows you to use some of your HX FX models before the CX in the signal path (e.g. OD, Comp), and some after the CX (e.g. MOD, Reverb, Delay). On the CX, set the Return switch to the Power Amp setting. You can use the HX FX models in conjunction with the CX FX models as well if you wish. Give it a read and experiment. It can be confusing at first so don’t hesitate to come back with questions.
Thanks for that Craig, very helpful.
unk65 started following CX 200 with Helix FX as midi control question
Hi folks! Just got a catalyst cx 200. I had a helix fx lying around and saw that I can use it as a midi control. From what I have seen so far, I can use it to set up channel switching and controlling the effects in the amp. My question is this: can I also use the effects in the helix fx with the amp via the same connection? How would I do this? Because all I can find out is how to use what is already in the amp via the helix fx. Sorry for the newb questions. Thank you in advance.
Hey StratBoss - I think the GR-55's guitar modeling is good. IMHO I think the Variax sounds closer to the real thing and WB can get you closer. But the the GR-55 has guitar modeling based on BOSS/Roland’s VG-99 COSM (Composite Object Sound Modeling). I know that a few pros did or still do use the VG-99 (like John Mclaughlin, Vernon Reid, Robert Fripp, Adrian Belew, Frank Gambale, Jeff Baxter, Steve Stevens). It just boils down to which one sounds/feels best to you. One plus for going the Roland route is that you can put the 55's GK pickup onto any guitar - so your favorite axe can have all the capabilities of the GR-55 and still feel like your favorite gear. I use the GR-55 with a Roland Ready (MIM) strat so I don't have the ugly GK controller and divided pickup wires showing. I had a Vax600 with the GK pup on it and it was cool to mix the Variax real guitar with the modeled guitar and the COSM guitar sounds together with 2 GR's synth sounds (a blend of 5 noises from one guitar at once). Only way to tell is A/B them yourself and then it will be your opinion not mine. I don't know what it says that both companies have respectfully discontinued these 2 products.
DavidNug started following Custom tone site change
Lindafrapy started following Using Amp Sims with Helix--Tone Loss?
Press and hold the Channel button (A or B) where you wish to SAVE the preset. When the LEDs start blinking you can release the button. I don't think you can manually SAVE an existing preset to a different Bank.
Quick question. Can you save presets by just using the amp or do you need to do it using the software? Thanks.
ZacharyCer started following EJ Inspired HX Stomp Preset - FREE
Thank you!
ErnestoElony started following HX Preset - A good Starting point for Rock / Metal Tone
HenryWes started following No signal out
Thanks Schmalle for your reply. Looks like I bought the wrong controller...
Here's the difference! I have my volume knob on both set to control the headphones and line outs. When line outs are excluded from being controlled by the volume knob they default to max. I'll need to check in Ableton, but I'm guessing I'll see similar volume output levels that you're seeing.
Bom dia a todos. Estou com um problema. Se alguem ja passou por isso e puder me dar uma dica. Tenho uma Pedaleira Firehawk, porem não consigo instalar no meu celular, Sansung S22 Android atualizado. Alguem sabe se tem alguma maneira?
What version is the driver you’re using? Did your download the Windows 8 compatible version?
ceedjay started following Cannot Reach Servers error
Hi ! After updating to PG Edit 2.0 I could not connect to my account via the program whereas I could access my account directly on Line6 website. So, I could not update firmwares properly. I recently got a laptop with Windows 10/11. My regular machine is running Windows 7 pro. I installed PG Edit on the new laptop and it logs in to my account without any problem. Don't know if the problem is Windows-version related or if it's just how my Windows-Seven computer is set up, but if You are getting the same problem with older OSs it might be the reason. I also have a computer running W8.1 and it seems to work. The rest of PG Edit functions works without any problem. Bye. Jay
No, the Engl Z12 can only send MIDI PC (program change) messages - you can use it switch select presets. It can't send CC messages which are required to do the stuff you asked for.
Had mine for about 9 months and I've basically now settled on a single patch for guitar, with 4 snapshot variations within it. To my mind, the appeal of the Pod Go (and probably all modellers) is that it's an all-under-one-roof solution that plumbs straight in the PA, with no humping heavy gear around up and down flights of stairs. Sound guys love it. It's quick, efficient and sounds more than good enough. It really comes into its own when playing bass as there's nothing more disruptive to a good onstage sound than a thundering great bass rig pounding away. So yeah - for me the depth of the menu is great, but once you've found your sound, lock it in and forget about it :-)
Hi everyone, the Engl Z12 midi controller has 10 switches, which I would like to use to switch between snapshots, turn blocks (e.g. effects) on/off... Has anybody here used this controller (or another Engl midi footcontroller) with the HX Stomp ?! Thanks Vincent
Amp effects loops are notoriously variable. Some pre-amps output a reasonable level to their power amps, and other pre-amps have a very high output, which their power amps expect as an input for them to work effectively. This is particularly so with amps that have cascading gain stages. Some are known to pump out 30 volts from pre-amps, and this will be what they output from their Send. Obviously, their power amps are expecting a similar level to their Return, to match what they would get direct from the pre-amp without the effects loop, but no digital modeller is going to deliver that sort of level. If you have one of these amps, all you can do is to max out everything short of digital clipping as advised by Schmalle. You could try using an "always on" conventional boost pedal between the HX Stomp output and the amp Return.
FX Loop ON (Edit App>Settings) MFX w/Amp sim (Cat as powered speaker): Output from the MFX(LINE LEVEL)>Cat60 Return Mode Switch=Power Amp In MFX w/Cat Amps/FX: Output from the MFX(INSTRUMENT LEVEL)>Cat60 Input Mode Switch=FX LOOP MFX 4cm (Cat Amps): MFX Send (INSTRUMENT LEVEL)>Cat Input>Cat Send>MFX Return)>MFX Output>Cat Return WITH Cat POST FX>Mode Switch=FX LOOP WITHOUT Cat POST FX>Mode Switch=Power Amp In
