Line6Pete1
In case you need to perform a pedal calibration for your Firehawk FX. Here are the steps:
1. Hold down footswitch A while powering on the unit. At startup the display will show "00" and footswitch D LED will be lit.
2. Press footswitch D to begin. The display will change to "01" and footswitch D LED will turn off.
3. Press the pedal forward firmly to toggle the pedal toe switch. The display will change to "02" and footswitch D LED will be lit.
4. Move the pedal to the heel position.
5. Press footswitch D. The display will change to "03" and footswitch D LED will be lit.
6. Move the pedal to the toe position (do not click the toe switch).
7. Press footswitch D. The display will change to "04".
8. Move the foot pedal and watch the values change on the display. Values will scroll from a min. of 0 to a max. of 99.
9. Press footswitch D to save the calibration values. The display will change to "05".
10. Power cycle the unit and your pedal is calibrated.
