M9 Stompbox Modeler FAQ
Total Looper Recording Time: 30 seconds (60 seconds with half-speed enabled)
Ins and Outs: Stereo Input through two 1/4" mono inputs (L and R) and stereo output through two 1/4" mono outputs (L and R). All inputs and outputs are unbalanced instrument level. Additionally, two 1/4" jacks for 2 expression pedals
Expression Pedal: Use Line 6 EX-1 or an expression pedal with a passive 10K ohm mono linear taper pot, using a standard 1/4 inch mono instrument cable
Power Adapter: included Line 6 PX-2 only (Specs: 9V, 2000mA, center tip positive, 2.5mm diameter). No battery power option available
Product Dimensions: 10.5" (L) x 7" (W) x 3" (H)
Weight: 2.3 lbs
Q: How many total effects are there in the M9?A: With the latest 2.01 Firmware update, there are 109 total effects available on the M9.
Q: How many of each type of effect is there on the M9?
A:
  • Distortions/Comps/EQ/Volume: 30
  • Modulations: 22
  • Filter/Pitch: 26
  • Delays: 19
  • Reverbs: 12
Q: How do I register my M9?
A: You can register any Line 6 product to your account here: Registration. For more detailed registration help, please see the Product Registration F.A.Q.
Q: What is the warranty on the M9?
A: Twelve months from the date of purchase. Any Authorized Line 6 Service Center you visit will need you to provide a copy of the purchase receipt to validate date for warranty processing. Please be sure to have those materials ready, should you need to get your unit serviced under warranty.
Troubleshooting & Service
Q: How do I perform a Factory Reset on the M9? A: You can perform a factory reset by entering the Setup screen (press both B1 and B2 at once) and navigating to the Screen with the MIDI, GATE, Display header and turning the Model Select knob until the corresponding parameter displays RST FACT? You can then press down on the TAP footswitch then the Model Select Knob together twice to reset the unit. You can also re-install the flash memory to return the M9 to factory settings.
Q: What is a "Scene"?
A: A "scene" is a pedal board arrangement on your Line 6 M9 Stompbox Modeler with 6 available effects, up to 3 at once.
Q: How many scenes are there and how do I access them?
A: With the 2.01 update, you can create and save up to 6 different scenes in one Scene Folder. With 4 Scene Folders, you get 24 total scenes on the M9! Press 3A and the TAP button at the same time to access the scenes and turn the MODEL SELECT knob to access the additional folders.
Q: Can I backup my scenes to my computer?A: You can backup your scenes via MIDI. Check out the M9/M13 Scene Backup document.
Q: Which expression pedals can I use with the M9?
A: We recommend using the Line 6 EX-1 expression pedal. You can also use any other expression pedal containing a 10k Ohm Potentiometer. Expression pedals allow you to change stompbox controls using your feet so you can adjust the sound while you play. On the fly, you can modify the delay time and feedback, speed of your tremolo, or sweep the pitch on the Pitch Bender effect.
Connect an expression pedal to your M5 Stompbox modeler. Start with the pedal in the toe position. Once you have your effect parameters settings as desired rock the expression pedal to its heel position. Now set your parameters to your desired settings. As you move your expression pedal from heel to toe, you'll see all of the adjusted parameters move between these settings.
All parameters affected by an expression pedal will show a pixel notch at the top indicating a parameter's setting for the toe position of the pedal. You'll also see a notch at the bottom that indicates a parameter's settingwith the expression pedal in the heel position.
Additionally, if you don't want a parameter adjusted by the expression pedal, set the parameter's knob to where you want it with the heel down, then do the same with the heel up.
