Q: How much battery life should I expect with my XDR95 transmitter?
A: During our in-house testing of alkaline battery performance, Kirkland, Energizer and Ray-O-Vac brands showed the best results. There are various test results available online that confirm this information. You should also be aware that there are black-market knock-offs out there that look “real†but fall short of the original manufacturer’s specifications. Line 6 digital wireless products now include Energizer batteries as others have not been performing up to spec. That being said, you should expect the battery life in the XDT4 to be between 5.5 and 6.5 Hours. Digital wireless technology has its own set of power demands, but as we develop products, we keep in mind the need for power efficiency. There is a big difference between 10 hours and 5 hours, but please remember the sound quality and benefits of the Line 6 digital system when compared to analog wireless.
Q: Is the battery used in the receiver of the XDS95 overridden when using the AC adaptor input?
A: In the current design, the battery is not overridden. What this means, is that if you plug in a power adapter to the XDS95 while there are working batteries in the receiver, the battery life will be drained in that configuration. Just make sure to remove the batteries if you are using a power adapter with the receiver.
Q: Can I use rechargeable batteries with my Line 6 digital wireless system?
A: Yes, but the specs on rechargeable batteries is all over the map and changes every time a battery is charged and discharged. In order to create and offer consistency, we have designed Line 6 digital wireless products to be used with standard 9V alkaline batteries. This way, we can predict and report battery life remaining with accuracy and translate that data to the battery meters that are included on Line 6 digital wireless components. Our knowledge of how consistently rechargeable batteries will work with the Line 6 digital wireless systems is limited. The rule of thumb is: As the battery remains above 6.2 V, it will continue to function. You may want to contact the battery manufacturer for further details.
Q: What power supply should I use for the XDS-95 system?
A: The Line 6 DC-1/DC1-G power supply will correctly power the XDS-95 system.
Q: What power supply should I use for the XDS-plus or XDR95 system?
A: the Condor 500ma power supply (supplied with the unit) or Line 6 DC1-G will power either the XDR Plus or XDR95 systems.
Q: Where can I find more information on the power supply requirements and purchase a replacement/spare power supply?
Power Supply, Amp Power and Battery F.A.Q.
Q: Will my XDR95, XDS95 and XDSPlus work with 230/240 volt power?
A: Yes, as long as the power transformer converts to 9V 500mA (For XDR95 & XDSPlus) and 9V 100mA (for XDS95) it will work. Our non-U.S. distributors sell 230V to 9V 500mA transformers.
Q: I have a pedal board that distributes power to all my pedals. Can my XDS95 receiver share power with devices?
A: Yes. Your XDS95 receiver only requires 9V 100mA, but the device will draw only what it needs. On pedal boards that share power with multiple devices, a device may not always get all the power that it needs. If power is being shared with other devices and you start experiencing any issues, dedicate power to the XDS95 and see if the issue goes away.
