Sign in to follow this
2.4GHz Wireless FAQ
  • https://line6.com/media/ips/uploads/monthly_06_2016/ccs-411956-0-99842700-1466467544.png,monthly_06_2016/ccs-411956-0-46436200-1466467556.png,monthly_06_2016/ccs-411956-0-70553900-1466467577.png
Deutsch
Français
Q: Why is the battery meter higher when I restart than when I shut off the transmitter?
A: Line 6 2.4G wireless transmitters have a circuit that measures the actual real-time voltage of the installed batteries and transmits that data to the battery meters in the receivers. The battery meters are very accurate when they have been running continuously since new batteries were installed in the transmitter and the transmitter power has not been cycled on and off. However due to the chemical nature of Alkaline batteries, when they have been shut off, the voltage begins to “rebound “ and the voltage actually increases compared to its value at shutoff. Unfortunately it does not last long and it reverts to true self over twenty minutes or so. For this reason when you first turn on a Transmitter that has been run but allowed to rest the meter will give a high reading that quickly falls over the first few minutes and continues to fall quickly for the first few minutes. This is normal behavior for Alkaline batteries.
Q: Why does my wi-fi slow down when I get my transmitter near my computer?
A: Because wi-fi and Line 6 2.4G wireless products share the same bandwidth some users may experience a slowing down of their wi-fi capabilities when using microphone or instrument transmitters near computers. This is an example of a near/far interference problem and it is heightened because consumer grade wi-fi has very low power. If your Line 6 transmitter gets within 6 feet of your laptop you may witness this situation especially if your wi-fi access point is some distance away. Typically simply moving your Line 6 transmitter farther away from your computer will remedy the situation. Users of Line 6 twelve channel systems should switch their transmitters to the “low power” setting as this will mitigate the problem as well.
Suggested channels settings to avoid interfering with wi-fi:
Q: What does the Near/Far spec mean to me?
A: The Near/Far interference problem is common to most radio systems and happens when a strong signal captures a receiver making it difficult or impossible for the receiver to decode the weaker signal.
Imagine having a conversation in a quiet room with a person 20 feet away from you. It is likely that you can carry on a conversation with normal voice levels. Now if you move to a noisy environment, with lots of other voices right around your ears it may be very difficult for the conversation to continue with your long distance friend without the both of you shouting.
A similar circumstance occurs with radios and since the long distance transmitter is incapable of increasing its power output it is very likely a very near transmitter may interrupt it.
In the real world this is rarely an unmanageable problem. You should avoid being closer than 3 feet to a receiver that is not on your channel if the intended transmitter is more than 50 feet from this receiver. If this is a regular requirement you will need to remote your antennas (G50, G90 XD-V70).
FAQ zu 2.4GHz Wireless
Warum ist die Batterianzeige höher wenn ich den Transmitter neustarte als wenn ich ihn abschalte?
Line 6 2.4G Wireless Transmitter haben eine Schaltung integriert, welche die Spannung der installierten Batterien in Echtzeit misst und diese Daten dann an die Batterieanzeige im Empfänger sendet. Die Batterieanzeige ist dadurch sehr genau wenn das Gerät durchgehend gelaufen ist nachdem neue Batterien eingesteckt wurden und der Transmitter nicht abgeschaltet und neugestartet wurde. Aufgrund der chemischen Natur von Alkaline Batterien nimmt die Spannung jedoch ab wenn das Gerät abgeschaltet wird und übersteigt dann den Wert den sie hatte vor dem Abschalten. Leider hält dies nicht lange und springt wider auf Normal zurück nach ca. 20 Minuten. Wenn Sie also zum ersten Mal einen Transmitter anschalten der vorher gelaufen ist, wird Ihnen die Batterieanzeige eine hohe Anzhl ausgeben, die dann aber schnell wieder fällt innerhalb der nächsten Minuten. Das ist ganz normal für Alkaline Batterien.
USB 3.0 Computerkabel und –geräte sind dafür bekannt Interferenzen bei Radio Frequenzen im 2,4GHz Bereich zu erzeugen was zu verringerter Reichweite und Performance für alle 2.4GHz Geräte (inklusive kabellose Tastatur oder Maus sowie WiFi und viele andere) in der Nähe führen kann. Wir empfehlen alle digitalen Kabellosempfänger mindestens 2m von den USB 3.0 Geräten und deren Verkablung weit weg zu plazieren.
Warum wird mein WiFi langsamer wenn ich meinen Transmitter in die Nähe des Computers bewege?
Da sich WiFi, sowie Line 6 2.4G Wireless Produkte die selbe Bandbreite teilen kann es sein, dass das WiFi bei manchen Benutzern langsamer wird wenn Sie Mikrofone oder Instrument-Transmitter in der Nähe von Computer verwenden. Dies ist dann ein Beispiel für "Near/Far" (Nah/Weit) Interferenzen und wird noch bestärkt dadurch, dass WiFi Produkte für den Endverbraucher eine sehr schwache Signalstärke haben. Wenn Ihr Line 6 Gerät sich innerhalb der Reichweite von 2 Metern zu Ihrem Computer befindet, kann dieses Problem auftauchen, besonders dann, wenn der WiFi Zugriffspunkt ein wenig weiter entfernt steht. Normalerweise können Sie dann einfach den Line 6 Transmitter weiter weg platzieren, was Ihr Problem lösen sollte. Benutzer eines Line 6 Systems mit 12 Kanälen sollten Ihren transmitter auf "low power" stellen, was das Problem dann auch behebt.
Empfohlene Kanaleinstellungen um Interferenzen zu vermeiden:
Was genau heißt das Near/Far?
Die Near/Far Interferenzen sind bei Funksignalen sehr verbreitet, da diese entstehen, sobald ein starkes Signal einen Empfänger sozusagen "einnimmt", was es sehr schwer macht für den Empfänger ein schwächeres Signal zu entschlüsseln.
Stellen Sie sich einfach eine Konversation in einem ruhigen Raum vor. Sie sind 6 Meter von Ihrem Gesprächspartner entfernt und können sich eigentlich ohne die Lautstärke zu heben mit diesem unterhalten. Wenn Sie diese Konversation nun in eine laute Umgebung verlegen, in der viele Gespräche rund um Sie herum stattfinden, wird es sehr schwer sich zu unterhalten ohne anfangen zu müssen zu schreien.
So ähnlich geschieht es mit dem Funksignel, da der Transmitter nicht die Möglichkeit hat seine Signalstärke zu erhöhen, kann es sehr gut sein, dass ein näherer transmitter dies unterbricht.
In der Realität ist das Problem in den meisten Fällen schnell zu lösen. Sie sollten es vermeiden näher als 1 Meter zum Empfänger zu sein, der nicht auf Ihrem Kanal ist, wenn der Transmitter der eigentlich mit disem Empfänger verbunden sein soll sich weiter als 15 Meter von diesem befinden. Wenn das eine regelmäßige Anforderung für System sein sollten, müssen Sie wahrscheinlich Ihre Antennen verlängern. (G50, G90 XD-V70)
2,4GHz Wireless F.A.Q.
Pourquoi est-ce que la jauge de batterie est plus haute si je redémarre que si j'éteins le transmetteur?
Les transmetteurs sans fil 2,4GHz de Line 6 les émetteurs comportent un dispositif qui mesure la tension des piles en temps réel et transmet ces données aux jauges de batterie dans les récepteurs. Les jauges de batterie deviennent très précises si ils ont été en cours d'exécution sans interruption depuis nouvelles batteries ont été installées dans l'émetteur et si le transmetteur n'pas été éteints et allumé. Mais à cause de la naturel chimique des batteries Alcaline, si ils ont étés éteints, la tension commence à "rebondir" et la tension augmente en comparaison avec la valeur de tension pendant être éteint. Malheureusement, cela ne durera pas longtemps et il revient à la valeur vraie après plus ou moins vingt minutes. Pour cette raison, lorsque vous allumez un émetteur qui a été exécuté avant, l'appareil donnera une tension élevée qui tombe rapidement au cours des premières minutes et continue de diminuer rapidement au cours des prochaines minutes. Ce comportement est normal pour les batteries Alcalines.
Pourquoi est-ce que mon WiFi ralentit si je place mon émetteur près de mon ordinateur?
WiFi et les produits sans fils Line 6 partagent la même bande passante, certains utilisateurs peuvent rencontrer un ralentissement de du WiFi à cause du placement du microphone ou des émetteurs d'instruments près ordinateurs. Ceci est un exemple d'un problème d'interférence "Near/Far" (près/loin) et est renforcé parce que les appareils WiFi consommateurs ont une puissance très faible. Si le transmetteur Line 6 est très proche (moins que 2 mètres) de votre ordinateur sans fil, vous pouvez rencontrer de cette situation, surtout si votre point d'accès WiFi est un peu plus loin. Normalement, si vous déplacer le transmetteur Line 6 plus loin de votre ordinateur, sa résous le problème. Les utilisateurs des systèmes Line 6 avec 12 canaux doivent mettre les émetteurs sur la configuration "low power". Ca résous le problème également.
Configurations suggérés de canaux pour éviter des interférences WiFi:
Qu'est-ce que le "Near/Far"?
Le problème d'interférence Near/Far est commun pour les systèmes radio et se produit, si un signal fort capture un récepteur, s'est très difficile pour le récepteur de décoder le signal plus faible.
Imaginez une conversation dans une chambre tranquille avec une personne 6 mètres plus loin. Il est probable que vous pouvez avoir une conversation avec des niveaux de voix normale. Si vous passez à un environnement plus bruyant, avec beaucoup de voix autour de vous, vos oreilles il peut être très difficile pour la conversation de continuer avec votre ami de longue distance sans crier.
Un cas très similaire se produit pour les radios et puisque l'émetteur de longue distance est incapable d'augmenter sa puissance, probablement émetteur un très proche interrompre.
En réalité, c'est principalement un problème résoluble. Vous devez éviter d'être plus proche qu'un mètre du récepteur qui n'est pas sur votre canal si l'émetteur destiné est plus loin que 15 mètres de ce récepteur. S'il s'agit d'une condition régulière, vous aurez besoin d'éloigner vos antennes. (G50, G90 XD-V70).
