Sign in to follow this
How to Update G10 Transmitter Firmware via Spider V Amps
Overview: For those who have access to a Spider V (MKI or MKII) amp and wish to update the G10T Transmitter, it must be done in the order shown below (first update the amp, then the G10). We strongly suggest updating the amp with the latest version of the Line 6 Updater from a desktop/laptop computer, even though it is possible to do so from a mobile device.
Video Tutorial: Updating a Relay-Ready Spider V Amp and G10T Transmitter With a Mac Computer
Video Tutorial: Updating a Relay-Ready Spider V Amp and G10T Transmitter With a Windows Computer
I. Update the Spider V Amp Firmware With a Computer
  • First, (for Windows users) download and install the Spider V drivers
  1. Go to Line6.com and click on "Support"
  2. Select "Downloads" and set the three pulldown windows under "Free Software Downloads" to: [Spider V 60], [Line 6 Drivers], [your PC OS]
  3. Click "GO"
  4. The page will update with the Line 6 drivers for the Spider V. Click 'GET DOWNLOAD' to download the driver installer to your computer.
  5. Log in to your free Line 6 User account (or create a new account)
  6. Click on 'ACCEPT AND DOWNLOAD' and follow the instructions to save the driver installer
  7. When the installer has been downloaded, double-click on it and follow the instructions to install it in your computer
  • Next, download and install the Line 6 Updater for Spider V
  2. Select "Downloads" and set the three pulldown windows under"Free Software Downloads" to: [spider V 30], [Line 6 Updater], [your Mac or PC OS]
  3. Click "GO"
  4. The page will update with the Line 6 Updater for the Spider V. Click 'GET DOWNLOAD' to download the updater program to your computer.
  5. Click on 'ACCEPT AND DOWNLOAD' and follow the instructions to save the updater installer
  6. When the program has been downloaded, double-click on it and follow the instructions to install it in your computer
  • Lastly, update the Spider V amp
  1. Connect the Spider V’s USB port to your computer with a traditional USB cable
  2. Slide the "SELECT" switch to the USB port labeled Mac/PC
  3. Turn the amp on
  4. Open the Line 6 Updater application and sign in with your Line 6 User Account
  5. Click on the Spider V amp
  6. Click the “Update” button next to the latest firmware version at the top
  7. Follow the prompts to begin the update process
  8. Do not turn off or unplug your Spider V or computer during the update
  9. Watch for the update status to be completed on the Spider V LCD.  Once completed, the amp will restart.
  10. Disconnect and reconnect the USB cable, then repeat the process for the G10T Transmitter
Note:
If you experience a failed update or your amp locks up during boot up, you can hold down the Amp and FX buttons to enter Update Mode. Once it's in Update Mode, attempt the update procedure again.
II. Update the G10T Firmware with the Spider V Amp
  • Make sure the Spider V amp is still connected to the computer, and that the computer is still connected to the internet
  • Insert the G10T all the way into the Spider's Input jack
  • Ensure that the "SELECT" switch is still engaged with the USB port labeled "Mac/PC". Turn on your Spider amp if it's off.
  • Run the Line 6 Updater program. Sign in to your Line 6 User Account.
  • Click on “Relay G10T”
  • Click the “Update” button next to the latest firmware version. Follow the prompts to begin the update process. Important: Do not turn off or unplug your Spider V amp or computer during the update.
  • The Updater will say the amp is resetting, but take note of the amp's display, as it will continue updating, ultimately showing "Part 1 of 1 100% Updating Transmttr". The amp will reset itself, ending the update process.
Edited by Line6Tony
