Sign in to follow this
Relay G30 Wireless FAQ
Deutsch Français
Q: Where do I get a Relay G30 Series Wireless System for use in the US?
A: The Relay G30 is available at all authorized Line 6 dealers. To locate a dealer near you, please see our Dealer Finder.
Q: Where can I purchase replacement Relay G30 transmitters (TBP06) or receivers (RXS06)?
A: You can order them from any authorized dealer.
Q: What are the specs on the provided Relay G30 Series power supply (DC-1G)?
A: 9.6V DC, 500mA, pin center negative.? See the following link for more power supply FAQs: Power Supply, Amp Power and Battery F.A.Q.
Q: Can I use a Voodoo Lab Pedal Power Plus 2 to power the Relay G30 receiver?
A: Yes, but you will need to use the Voodoo lab "doubler" cable and you will need to use any two outputs of the Pedal Power Plus set to the "normal" position. See the following link for more information on the "doubler" cable available from Voodoo Lab:
Voodoo Lab cables
Q: What type of cable do I need between my guitar & Relay G30 (TBP06) transmitter?
A: Any mono (tip-sleeve) instrument cable will work for both the instrument to the transmitter and the receiver output. We do not recommend using TRS ("stereo") instrument cables.
Q: If you leave the transmitter cable plugged but turn the power off on the transmitter, does the cable still use up battery life even if the transmitter is powered off? Similar to some analog stomp boxes?
A: When the power is switched off, the audio input has no bearing on battery draw, cable in or out.
Q: Is the Relay G30 (TBP06) transmitter compatible with the X2 receiver (or vice versa)?
A: Both systems run in completely different frequency ranges so they are not compatible with each other, but X2 and Relay units can be used on the same stage (along with any other analog wireless systems) with no problems.
Q: I'm a harmonica player and would like to use the G30 with a bullet microphone (high impedance and high output). Its output peaks at approximately 3V to 4V. Will there be clipping or distortion of the output?
A: No problem with either impedance or input level. The Relay transmitters (TBP06 and TBP12) will handle 6V inputs.
Q: What is the output impedance of the RXS06 Receiver ?
A: The output impedance of the RXS06 Receiver is 200 ohms.
Q: How do I register my Relay G30 System?
A: You can register on your account:
Gear Registration
LED States:
TBP06
BATT:
Blue: On
Red: Low battery
Purple: On channel change
AUDIO:
Green: Signal at input
Orange: On power / channel change.
RXS06
POWER:
Blue: On
AUDIO:
Green: Signal at receiver input
Transmitter Status:
Top: Signal Strength
Bot: Tx Battery Life
F.A.Q.: G30 Wireless:
Où est-ce que je peux acheter un système sans fil Relay G30 en France/Belgique?
Le Relay G30 est disponible à tous les revendeurs Line 6 autorisés. Utilisez ce lien pour trouver un distributeur près de chez vous: Dealer Finder
Où est-ce que je peux acheter des Relay G30 émetteurs (TBP06) ou récepteurs (RXX06) de remplacement?
Vous les pouvez commander de n'importe quel distributeur autorisé.
Quels sont les spécifications d'alimentation fournie avec la série Relay G30 ? (DC-1G)
9,6V DC, 500mA avec broche centrale négative. Visitez ce site pour plus d'informations concernant les alimentations:
Est-ce que je peux utiliser un Voodoo Lab Pedal Power Plus 2 pour allumer le récepteur Relay G30?
Oui mais vous devez utiliser le câble Voodoo Lab "doubler" et deux sorties du Pedal Power Plus sur la position "normal". Visitez le lien suivant pour plus d'informations sur les câbles "doubler" disponibles de Voodoo Lab:
Câbles Voodoo Lab
Quel type de câble est-ce que j'ai besoin pour connecter ma guitare et mon transmetteur Relay G30 (TBP06)?
N'importe quel câble instrument mono (TS) fonctionnera pour la connexion de l'instrument à l'émetteur et à la sortie du récepteur. Nous ne recommandons pas l'utilisation d'un câble instrument stéréo (TRS).
Si vous laissez le câble instrument branché mais éteignez le transmetteur, est-ce que le câble toujours utilise la batterie même si l'émetteur est éteint? Comme pour quelques pédales d'effets analogues?
Si le transmetteur est éteint, l'entrée audio n'a pas d'incidence sur la batterie, avec ou sans câble.
Est-ce que le transmetteur Relay G30 (TBP06) est compatible avec le récepteur X2 ou inversement?
Les deux systèmes utilisent des gammes de fréquences complètement différentes donc ils ne sont pas compatibles MAIS les deux peuvent être utilisés dans la même scène (avec autres systèmes sans fils analogues) sans problèmes.
Je suis un harmoniciste et je voudrais bien utiliser le G30 avec un micro harmonica (impédance et sorite haute). Sortie d'environ 3V à 4V. Est qu'il y aura du clipping ou de la distorsion du signal de sortie?
Pas de problème ni avec l'impédance ou niveau d'entrée. Les transmetteurs Relay (TBP06 et TBP12) peuvent traiter des entrées de 6V.
Quel est l'impédance de sortie du récepteur RXS06?
L'impédance de sortie du récepteurs RXS06 est 200 Ohms.
Comment est-ce que je peux enregistrer mon système Relay G30?
Vous le pouvez enregistrer ici: Enregistrement Line 6.
États LED:
TBP06:
BATT:
Bleu: Allumé.
Rouge: Batterie faible.
Violet: Changement de canal.
AUDIO:
Vert: Signal à l'entrée.
Orange: Allumé et changement de canal.
RXS06:
POWER:
Bleu: Allumé.
AUDIO:
Vert: Signal à la sortie.
État du transmetteur:
En haut: Puissance du signal.
En bas: Vie de la pile.
F.A.Q. zum Relay G30 Wireless:
Wo bekomme ich ein Relay G30 Wireless System in Deutschland her?
Das Relay G30 ist bei allen autorisierten Line 6 Händlern erhältlich. Um einen Händler is Ihrer Nähe zu finden klicken Sie auf diesen Link: www.de.line6.com/dealers/
USB 3.0 Computerkabel und –geräte sind dafür bekannt Interferenzen bei Radio Frequenzen im 2,4GHz Bereich zu erzeugen was zu verringerter Reichweite und Performance für alle 2.4GHz Geräte (inklusive kabellose Tastatur oder Maus sowie WiFi und viele andere) in der Nähe führen kann. Wir empfehlen alle digitalen Kabellosempfänger mindestens 2m von den USB 3.0 Geräten und deren Verkablung weit weg zu plazieren.
Wo kann ich Ersatztransmitter (TBP06) oder –empfänger (RXS06) kaufen?
Sie können diese bei autorisierten Händlern erwerben.
Was sind die technischen Daten zum Netzteil der Relay G30 Serie (DC-1G)?
9,6V Gleichstrom (DC), 500mA, negativer Zentralpol. Klicken Sie auf den folgenden Link für weitere Informationen über Netzteile zu erhalten:
Kann ich ein Voodoo Lab Pedal Power Plus 2 benutzten um den Relay G30 Empfänger zu betreiben?
Ja, aber dazu brauchen Sie ein Voodoo Lab "doubler" Kabel und Sie müssen zwei der Ausgänge des Pedal Power Plus verwenden, die auf "normal" eingestellt sind. Klicken Sie auf den folgenden Link um mehr Informationen über "doubler" Kabbel von Voodoo Labs zu erhalten:
Voodoo Lab Kabel
Welche Art Kabel brauche ich zwischen meiner Gitarre und dem Relay G30 Transmitter (TBP06)?
Irgend ein Mono (TS) Instrumentkabel wird funktionieren für die Verbindung von Instrument zu Transmitter und zu Empfänger-Ausgang. Wir raten davon ab ein Stereo (TRS) Instrument-Kabel zu benutzen.
Wenn man das Transmitterkabel stecken lässt aber den Transmitter selbst abschaltet, verbraucht das Kabel dann weiterhin Batterielaufzeit obwohl der Transmitter aus ist? So wie bei manchen analogen Effektpedalen?
Wenn das Gerät abgeschaltet ist, dann hat das Kabel keine Einfluss auf die Batterielaufzeit ob das Kabel steckt oder nicht.
Ist der Relay G30 Transmitter (TBP06) kompatibel mit X2 Empfängern, bzw. umgekehrt?
Beide Systeme laufen in vollkommen anderen Frequenzbereichen und sind somit nicht komaptibel, Sie können Sie jedoch ohne Probleme (mit anderen analogen kabellosen Systemen) auf der selben Bühne benutzen.
Ich bin ein Harmonikaspieler und würde gerne das G30 mit einem Kugelmikrofon benutzen (hohe Impedanz und Ausgang). Der Ausgang befindet sich da höchstens bei ca. 3V oder 4V. Wird dies zu Übersteuerung oder Verzerrung am Asugang führen?
Nein, weder Impadanz noch Eingangspegel sind hier ein Problem. Die Relay Transmitter (TBP06 und TBP12) kommen mit Eingängen von bis zu 6V klar.
Was ist die Ausgangsimpedanz des RXS06 Empfängers?
Die Ausgangsimpedanz des Empfängers beträgt 200 Ohm.
Wie kann ich mein Relay G30 System registrieren?
Line 6 Produkte können über das Benutzerkonto auf de.line6.com registriert werden.
http://de.line6.com/account/registergear/
LED Zustand:
TBP06:
BATT:
Blau: An.
Rot: Niedriger Batteriestand.
Violet: Auf Kanalwechsel.
AUDIO:
Grün: Signal am Eingang.
Orange: An und auf Kanalwechsel.
RXS06:
POWER:
Blau: An.
AUDIO:
Grün: Signal am Empfängereingang.
Transmitter-Status:
Oben: Signalstärke.
Unten: Batterielaufzeit.
